Gear shift lever comes out of transmission 51B
Marc
01-04-2004 12:12:44
I have a 51 B that the gear shift lever comes out of the transmission when pulled up. What usually causes the problem. The ball or the plate that holds the ball. Should I replace both of them and are they still available? The ring that mounts below the ball is paper thin and needs replacing but the ball will pull through the plate at the bottom of the gear selector galley.
Clooney
01-04-2004 13:01:32
 Re: Gear shift lever comes out of transmission 51B in reply to Marc, 01-04-2004 12:12:44
Marc, if the shift lever isn't pulling through the ball [a common problem if the lower ring isn't holding], then you probably have a worn ball socket [that would probably be the case if the whole ball pulls through]... You more than likely have wear on the ball also but you will have to look at it & maybe even try it in a new ball seat to determine if it's excessive..
[email protected]
Stan - Florida
01-04-2004 12:32:00
Marc,
I can't help you solve the problem, but a buddy of mine had the same problem, so I did scan the page of Parts Catalog PC-330 that shows the illustrated parts breakdown of that shifter mechanism. I could e-mail that to you if you like, maybe it will help you figure out what's missing or broken. E-mail me at [email protected] if you want that scan sent.
Stan
