JD front and wheel weights
rctn
02-18-2003 18:19:04
isn't there a foundry that casts tractor weights? Does anyone know how to get in touch with them? I am looking for the flat starter weight, front weights and wheel weights for 3020/4020.
Heat Houser
02-19-2003 18:59:34
 Re: JD front and wheel weights in reply to rctn, 02-18-2003 18:19:04
There were two styles of front weight starter brackets that will fit a 4020/3020/4010/3010.
The first is an all cast bracket that was poured in two halves and it bolted to the side frames and to the the front casting. Additional slabs were then bolted to this.
The second type was a three piece affair where the side pieces were fabricated from steel plate, again bolted to the tractor side frames (by the engine) and then a double front starter weight was attached to it. The double weight would allow you to have two rows of slabs. This double weight would also fit the 30 series such as a 4630, 4430 etc. There is an auction in Oregon, IL this Friday that had some of the single starter weights on the sale bill. Oregon Illnois is south of Rockford and is the home of Woods Mowers and Etnyre asphalt equipment.
I have the double weight on my 4010 and five slabs to handle big round bales.
jared
02-19-2003 10:23:28
for the front, the two starting brackets and 3 weights is all that we have on our 2510 and that worked real well with hualing round bales on the back and a brush hog
Ralph
02-18-2003 20:50:04
You should be able to find the original rear wheel weights on a farm auction. About $100 a set. I have bought several, two sets headed for a 4020, and had planned on 2 more on the 820, but it seems to grab the dirt prety well with 3 sets, 2 inside and one outside. Don't know much about the fronts. 4020 seems to stay down, but doesn't see a full load on the three point.
