JD 2040
Wayne
01-04-2004 11:23:55
I am about to buy a JD 2040 tractor to keep it in the family. I do not know much about this tractor. I know it has been taken very good care of. I was wondering if anyone knows anything about these tractors. Following are the only details that I have.
3 cyl. deseil
about an 80's model
they say there is no hydo. but not sure that is one of my main questions
If anyone has any info about these tractors please let me know as much as you can.
Thanks
MIKE HANLEY
01-04-2004 17:50:31
 Re: JD 2040 in reply to Wayne, 01-04-2004 11:23:55
The 2040 was made from 1976 starting with serial # 179963 through 1982 starting tahe year with serial # 419145. The 2040 was rated at 40 horsepower with a 3 cylinder vertical, valve-in-head, 4-stroke-cycle diesel with engine RPM's of between 1500 and 2500.
Bore and Stroke 4.02 X 4.33. Giving a 164 cu in
Standard trasmission was collar shift with 8 speeds forward and 4 in reverise. Cluch was a two stage cluch for tractor movement and making the 540 PTO "live". Standard rear tires were 13.6 X 28. Shipping weigth (tractor dry, no fludeds) 4060#.
NO hydro means that the tractor has the standard transmission and is NOT equipted with the optional Hydrilic HI/LOW.
Generaly speaking, a nice little chore tractor and could be equiped with a JD loader, but it's your judment were this is a tractor that has had some care, or was rode hard and put up wet.
