JOHN DEERE MOVER #5
DENNY MCDANIEL
02-17-2003 15:53:44
NEED SET OF QUICK ATTACH FOR #5 MOVER have found the mower brackets at different places but have had no luck finding the other half. would take the whole set if available.
firedog
02-18-2003 15:36:47
 Re: JOHN DEERE MOVER #5 in reply to DENNY MCDANIEL, 02-17-2003 15:53:44
Denny,
Are you talking about the two Qwik-Tach arms that mount on a bar attached to the mower? If so , you may need to find a parts machine. They are cheap enough that you can usually buy the entire mower for what you will pay for the part.
Also, if you havn't done so already, get an Operators Manual ( Local JD Dealer )and all the parts and numbers are listed. The pictures and drawings should show you everything you need to know. I will look out in the barn in a few days to see if I have the item you have mentioned.I scrapped one a couple years ago but the arms might have been bent.
firedog
Chris
02-18-2003 13:43:16
Denny,
I have a 39B which there were no quick tach ever made for sooooo i made my own. Some heavy Iron a 1 3/4" bar is all ya need. Thanks i can help you more if you need just email me. Thanks
Dan
02-17-2003 20:03:01
I'm not sure exactly what you are looking for. There were a set of the brackets that mount on the tractor on E bay I believe the other day. I would think they would be easy to find. Same brackets were used on the #8 and I would think the A, B and G would be the same brackets.
Bus Driver
02-17-2003 16:21:39
Denny, it would be helpful to know which tractor, make and model-even the year, that the mower is to be attached to.
denny mcdaniel
02-17-2003 18:53:15
 Re: Re: JOHN DEERE MOVER #5 in reply to Bus Driver, 02-17-2003 16:21:39
IT IS A 1950 OR 51 B JD AT LEAST IT HAS THE SQUARE AXELS
