John Deere D Carb Removal
Walt
02-17-2003 09:52:33
I am trying to take the carb off but I am having some trouble removing the bolt on the back side, The hard to get at one,It is seized into the manifold. Any ideas are welcome.
Walt
02-18-2003 16:52:44
 Re: John Deere D Carb Removal in reply to Walt, 02-17-2003 09:52:33
Thanks for the help. I went at it with a modified wrench and the head of the bolt broke off, But now the carb is removed so I put some major heat around the bolt and attached vise-grips and it came right out. I think that i'll use a socket head bolt and use anti seize when I install it.
Walt
Paul from MI
02-17-2003 19:44:00
Walt,
Clooney's suggestion about the specially bent wrench is a good one. I could e-mail you a picture or sketch of one I made if it would help. Right now your biggest problem is getting it broke free without breaking it off in the manifold. That could lead to having to pull the manifold if you can't find a way to drill & re-tap the hole. I think I'd try some PB Blaster(get it at your local auto parts) every day for a week or two first. I've had some pretty good luck with it on old shackle and shock bolts. LOL
Paul
Clooney
02-17-2003 13:45:56
Walt, that is one of Deere's better designs & prevents anyone from easily stealing your carb-[well it sounds good anyhow].
~That carb bolt is a pain even when it isn't seized tight. A bent wrench & some heat might do trick. Sometimes removing the outer bolt then turning the carb & the bolt at the same time will work to break it free. You have to be careful as the carb base ear will break off easily if you force it too much. I usually can get them lose with a torch & small hot flame.
