70 gas hood
jd70
02-17-2003 05:25:18
Has anyone seen a 70 gas with the gas fill cap in the center of the hood?
Thanks
Putt Putt
02-17-2003 07:01:20
 Re: 70 gas hood in reply to jd70, 02-17-2003 05:25:18
JD70-----
Yes! At Serial #7012350 (which corresponds, roughly, with June, 1954) several minor changes were made to the 70. Included were updates to the Power Steering pedestal unit, power take off and moving the gas filler down towards the front of the tractor. Safety and convenience were cited in the bulletin to dealers.
Putt Putt
G Taylor
02-17-2003 07:49:53
 Re: Re: 70 gas hood in reply to Putt Putt, 02-17-2003 07:01:20
On all-fuel 70's the small gasoline tank filler stayed at the center far rear of the hood. The main tank fill and the gasoline tank fill for gasoline tractors was 4/5 of the way back on the left side above the left spark plug. Seems the occasional hurried farmer slobbered fuel and lit the tractor and surrounding area/equpment/buildings. At serial #7012350 the gasoline filler on gas tractors and main tank filler were moved to the front left of the hood. The hoods center crease kept most spills deflected off the exhaust stack.
Thanks
02-17-2003 11:36:11
 Re: Re: Re: 70 gas hood in reply to G Taylor, 02-17-2003 07:49:53
It is not an all fuel. It is just an early model 70 gas. Do you guys no how far out the needles on the carb should be on this tractor. It has the duplex carb.
Thanks Again
Dan
02-17-2003 06:19:42
Both my 70 gas standards have the cap on the side.
