Drilling ports for DLTX 53 carb
BMeyer
02-16-2003 08:24:13
This carb is for a 1941 AW. According to the parts book, item #40, which calls itself a plug, drill 7/32-32. Is this one of the areas that you drill to clean the port? Also the same thing with the orfice just above that on the carb? If so, what size bits for each port?
BMeyer (Thanks guys NT)
02-16-2003 10:04:49
 Re: Drilling ports for DLTX 53 carb in reply to BMeyer, 02-16-2003 08:24:13
Clooney
02-16-2003 09:28:30
BMeyer, the Roberts drill bit sales picture shows the main passages that need drilling out but those are just the main drillings that feed the smaller passages & bleeds. Use extreme caution not to use those drill bits in the smaller passages & ports. If any of the smaller holes are drilled out & enlarged, the carb metering could be adversely effected & it will be impossible to get the carb to meter correctly in all ranges.
~The main metering nozzle is also a very important part of the carb operation & the main nozzle should be pulled & all the little holes cleaned as well as the bowl vent drillings & baffles.
~I just E-Mailed you a picture of the DLTX areas the need attention for proper carb operation & metering. Use small wires for the orifice's & vent restriction
John T
02-16-2003 08:56:27
third party image
Good Morning Mr Meyer, The ports located behind those brass drill plugs you mentioned, are shown and identified at the Roberts Carb Repair Web Site and what size bits fit which passages.
Link
