Don, see the below API GL specs... ~The gear oil you used wouldn't be my first choice. You really don't need a high EP additive gear oil in a straight cut gear tractor & the EP additives do increase the erosion of non ferrous metals in the trans & rear axle.. [there is a lot of sulfur & chlorine in the high EP gear oils & that when mixed with moisture if not a good thing for gear & bearing erosion] ~The modern GL-5-6 gear oils are thinner & slipperier that the old original Deere GL-1 spec gear oils.. Your transmission will probably run quieter with a GL-1 spec mineral base oil in it.. ~I doubt that the GL-5 or 6 gear oil you used will really hurt anything but it will be a fair amount thinner than the original Deere gear oil.. ~Remember 85-140 gear oil is a modern high flow emission & fuel economy oil & is blended to flow out easier & reduce gear drag.. For all practical purposes it is just 85 weight gear oil the doesn't thin any more then 140 weight would when it get working hot.. The gear oil in a 2-cylinder Deere just doesn't get that hot so most of the time it will just be a thin 85 weight gear oil.. ~The advantages of the newer spec high EP gear oils are better cold shifting & a very slight reduction in gear tooth wear,, the disadvantages are not to friendly to yellow metals, does funny things when moisture is present [common in old tractor transmissions] , thinner, & leaks easier.. ~The original GL-1 gear oil is a mineral base gear oil that has a real thick base & clings to the straight cut gears better.. It is still used in machine oils for old lathes & older straight cut gear machines.. ~If you want to use a later GL- gear lube with some EP additive try to find some GL-4 gear oil as that is used in marine use & handles the moisture problems better.. ~Look at the actual GL- number that the gear oil [ACTUALLY IS].. Most newer gear oils are rated to cover a multi range of GL ratings & most can back cover the older ranges,, But there should be only ONE actual GL- number on the pail.. Like maybe, [says] GL-6_ meets GL- 4-5 & 6 specs.. That is actually GL-6 gear oil.. GL-1: Specified for automotive spiral-bevel and worm gear axles and some manual transmissions subject to mild service and that can be sensitive to some EP additives. These lubes usually contain rust and oxidation inhibitors, defoamants and pour point depressants but do not contain any EP additives or friction modifiers. GL-2: Specified for automotive worm gear axles that are subject to more severe service than that which is covered under the GL-1 specification. GL-3: Specified for manual transmissions and spiral-bevel axles operating under moderately severe service. GL-4: Specified for hypoid gear service without shock loading, but still moderate to severe service (high speed/low torque and low speed/high torque). These lubes may be used in manual transmissions and transaxles where EP additives are acceptable and typically contain a different zinc additive combination. This classification is still commonly used, but is also obsolete. It is also a commonly specified for marine outboard and stern drive lower unit gears and bearings where the manufacturer specifies GL-4 rated performance. GL-4 rates lubes are not recommended as a replacement for GL-5 rated lubes. �GL-5 rated lubes shows significantly better anti-wear (anti-score) properties than GL-4 rated oils under similar service conditions� GL-5: Specified for hypoid gears under shock loading and severe service operating conditions used in cars and trucks. This is the most common and widely used specification today. These lubes have a high level of EP additives and, depending on the manufacturer and formulation, could be mildly corrosive to non-ferrous parts in certain applications. GL-6: This classification is obsolete and/or was never formally adopted by the API, although I have seen some racing type gear lubes advertised as �high-performance GL-6�. It is more than likely advertised this way for marketing purposes We are now getting into the GL-7 & up synthetic ranges.. [email protected]
