Checking thermostat on 50
Roger
01-04-2004 09:17:43
Have an early model 50 ser#5016020 and have the nose nose off to tighten up the steering. Last summer even in hot weather the temp would not come up 1/4 way on the guage. after taking off the nose I see that the shutters are closed. would this tractor not warm up with the shutters closed during light work? Should I take the thermostat out and check same or just leave it alone? Thanks for any input
ron in MN
01-04-2004 10:51:55
 Re: Checking thermostat on 50 in reply to Roger, 01-04-2004 09:17:43
My 50 is much later (1955) and doesn't have shutters, but it has a new radiator core and thermostat. On warm summer days and light work it will only warm to 140 degrees. I suspect what you are experiencing is a faulty thermostat because even with shutters closed there can be a lot of indirect airflow. The fan on mine turns at a very fast rate and I would expect the same to be true of yours. Oh, one further note, mine has the small bypass around the thermostat. Not sure if yours has that, (I haven't checked my parts book lately) but if it doesn't have the bypass that would further indicate a bad thermostat.
Clooney
01-04-2004 10:41:54
Roger, those early in radiator T-stats are a real pain.. I wouldn't pull it out as it might leak afterwards.. Probably wouldn't do any good anyhow..
~Try lubricating all the shutter linkage & pivots & see [actually hope] that will get it working..
~If the [in radiator] unit is not working there isn't much available out there at a decent price to repair it..
~Most people just wire the shutters open or remove them.. I don't like that idea as it causes the engine to run too cold.. There are a few different things you can do. One is to convert to the later conventional T-stat [a big job],, the second is to disconnect the lower radiator T-stat linkage & rig up a manual control of the shutters with a choke cable or manual rod..
~Try the lubrication & see if the shutters & linkage are just frozen up with rust..
[email protected]
ron in MN
01-04-2004 10:59:45
 Re: Re: Checking thermostat on 50 in reply to Clooney , 01-04-2004 10:41:54
Clooney, I'm curious as to why you say to convert to manual control of the shutter? Roger mentioned the shutters are closed and he doesn't get it to warm up enough. The manual control of the shutters would only (in this case) allow him to open the shutters which would make it still harder to get the engine to warm up. Maybe there is something I'm missing as to the makeup of these older 50s.
Clooney
01-04-2004 11:08:29
 Re: Re: Re: Checking thermostat on 50 in reply to ron in MN, 01-04-2004 10:59:45
Ron, with shutters closed it will soon overheat when he puts it to work.. There is a big difference between idling it around & working it..
~It takes a long time to warm a shutter controlled system up as it has to warm the entire cooling system including the radiator contents.. With a conventional T-stat [like you have on your later tractor] all it has to do is warm the engine contents up..
~With a manual control he can leave the shutters closed for light loads & idling around & still be able to open the shutters for working situations..
[email protected]
ron in MN
01-04-2004 11:19:39
 Re: Re: Re: Re: Checking thermostat on 50 in reply to Clooney , 01-04-2004 11:08:29
Yes I understand all you are saying. I missed seeing where he mentioned that he planned to work it at its full capacity. Obviously then he would need to have a shutter opening available. Thanks.
Roger
01-04-2004 11:49:13
 Re: Re: Re: Re: Re: Checking thermostat on 50 in reply to ron in MN, 01-04-2004 11:19:39
I think I'll just leave it alone for now. Thanks to everyone who replied. I may take the nose off again in the Spring when it is to work a little and just see if the shutters are working. I think they may be as they are quite clean. I will lubricate them now.
buickanddeere
01-04-2004 17:37:36
 Re: Re: Re: Re: Re: Re: Checking thermostat on 50 in reply to Roger, 01-04-2004 11:49:13
Rather than wearing out the engine and putting raw fuel up the stack, a engine mounted thermostat can be added. From the 1st 50 to serial number 5016615 (early 1954) the rad shutter system was used. The Early gas 1954 5016616 now with pressurized cooling to late 1955 5029199 used casting #B3293 in place of #B3078R to hold a coolant flow controling thermostat between the block and coolant pipe to the rad. Should bolt right in. The 56 5029200+ used a bypass cooling system with the thermostat up near the rad.
ron in MN
01-05-2004 10:15:05
 Re: Re: Re: Re: Re: Re: Re: Checking thermostat on in reply to buickanddeere, 01-04-2004 17:37:36
b & d, You mention 56 5029200+ ----. My 50 is S/N 5030XXX and I have been calling it a 55 based on S/N charts I've seen. Do you have other verifiable S/N data to show it as a 56? Mine definitely has the thermostat up near the radiator.
buickanddeere
01-05-2004 11:52:28
 Re: Re: Re: Re: Re: Re: Re: Re: Checking thermosta in reply to ron in MN, 01-05-2004 10:15:05
She's a 56. Wondered about your earlier post, how there was a bypass around the stat. Looked it up on the CD parts rom and another refernce book. A birth certificate from Two Cylinder Club would date the main case and make a nice wall hanging. Have yet to get permission from my wife to display our tractor data in the house.
ron in MN
01-05-2004 21:31:48
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Checking therm in reply to buickanddeere, 01-05-2004 11:52:28
I requested data from Two Cylinder Club in the early 1990s when I first got this tractor. They stated it was manufactured in Oct 1955 so I've been calling it a 55.
