Fan shaft on model 50
Craig Daniel
02-15-2003 17:33:57
I posted this on tractor talk also before I realized there was a forum dedicated to JDs. I need to know how to get to the front bearings and packing on the fan shaft of a model 50 I have the assembly off the tractor with the fan , friction disc springs removed but I cant' figure out if the bearing housing threads on or drives on the tube or if you get to the bearings some other way. If anyone could help I would greatly appreciate it. THANKS
Clooney
02-16-2003 05:38:19
 Re: Fan shaft on model 50 in reply to Craig Daniel, 02-15-2003 17:33:57
Craig, not sure what Frank sent you but will presume a picture of the fan shaft.
~I will give you a short how-to on the fan shaft tube here...The bearing housing is pressed on the fan tube & is not removable [or at least shouldn't be removed]. To get the bearings out you have to pull the front felt retainer [caution: there's a spring behind the front bearing & felt retainer so watch it doesn't pop out & hit you in the eye or fly across the shop & hit something important... I usually pull the fan shaft out of the tube, then use a l-o-n-g piece or re-rod with a slightly bent end to go through the big rear washer & bearings then punch the front bearing & felt retainer out. You can get it apart by pushing real hard on the fan shaft, but by doing that you will be compressing the spring in the process & when it comes out it will really fly. You can also try to work the felt retainer out from the front but in most cases you will damage it....
F-I-T
02-15-2003 21:34:44
Craig:
Check your e-mail.
Frank-in-Tallahassee
