Help me date my B???
Denny Foster
02-15-2003 16:56:28
third party image
Here is a photo of my B with no serial number plate, it has the John Deere raised in the rear axle castings, the PTO shaft is 1 3/8". any help would be appreciated. I have been told that it is around 45.
Denny
Slofr8
02-17-2003 10:34:55
 Re: Help me date my B??? in reply to Denny Foster, 02-15-2003 16:56:28
In one post you stated that your frame "appears" to be angle iron. Someone else said that they can see that it is but I can't be certin from the dark picture. I have a '43 B with the cast frame and I must say it looks an awfull lot like yours but I might be wrong. An angle iron frame will be open underneth and cast will be full. Also, I see your grills are off. If you can find the part no. that is cast into the bottom tank of your radiator it would tell you what frame you have. B 2023 R was the tank used in the cast frame. It was a little narrower than the tank that was used in the angle iron frame. I'm not saying it "is" cast, only that I can't tell for sure.
Will P
02-17-2003 14:35:34
 Re: Re: Help me date my B??? in reply to Slofr8, 02-17-2003 10:34:55
Take a look at the main picture he has up. If you look threw the holes in the pulley side, you can see lite. The cast frame you won't see lite. I too have a cast frame 43B and a 43 angle iron frame A.
Will P
Slofr8
02-18-2003 09:02:08
 Re: Re: Re: Help me date my B??? in reply to Will P, 02-17-2003 14:35:34
Uncle.
DP
02-16-2003 07:52:22
From the front wheels it has, it is 1944 or eariler. The 45 models had the reversible front wheels and different hubs.
ChuckW
02-16-2003 07:49:22
It has the old drawbar assy so it is an early 40's model. By the way, HOW do you use it with that tire on backwards????? ???
Denny Foster
02-16-2003 08:59:34
 Re: Re: Help me date my B??? in reply to ChuckW, 02-16-2003 07:49:22
Have not used it I just got it from a fellow in Ohio who had it about 7 years and did not do anything with it.
Denny
And another picture
02-16-2003 07:15:26
third party image
flywheel side of the B
Will P
02-16-2003 07:18:15
 Re: Re: Help me date my B??? in reply to And another picture, 02-16-2003 07:15:26
Is that power lift or trol? There is a serial number on it. It is right on top.
Will P
Another picture of the B
02-16-2003 07:13:32
third party image
heres another picture of the B
Denny
Will P
02-16-2003 11:50:20
 Re: Re: Help me date my B??? in reply to Another picture of the B, 02-16-2003 07:13:32
Well, the draw-bar assembly is of 149699 and earlier. You state that it has 1 3/8" pto. It should have 1 1/8". But there was a kit to update the pto to "standard" size. You have 6 speed. Which came out for 41. You don't have the cast frame. Which came out after 300 tractors rolled off the Assembly line in 43. So, my best guess would be 41, 42 or the first 300 of 43.
Will P
Will P
02-16-2003 07:21:36
Ahh powerlift. What is the serial number?
Will P
Slofr8
02-16-2003 06:35:11
If your tractor has the cast iron front support,witch it seems to have, then this would fall into the ser. #'s 136662-166999.
They went to a pressure type radiator cap that looks like the one on your car ,witch your tractor does not have, from ser. # 148500-166999.
The chart that I have for the 1943 model year shows ser. #'s 136315-149218.
This would fall into the time frame that they used the tin ser. # plates that were prone to rusting away and probably why you don't have one.
Therefore, this would likely put your ser.# between 136662-148499 making your tractor a 1943.
Just my very uneducated opinion.
Will P
02-16-2003 07:16:41
 Re: Re: Help me date my B??? in reply to Slofr8, 02-16-2003 06:35:11
He states that it is angle iron frame. Which I can tell that it is. So it most likely is not a 43 and is positively not a 44. He has 1 3/8" pto. Which didn't come out until the beginning of 44. I have to state that it is PROBABLY NOT a 43.
Will P
43A
43B
49G
John Ne.
02-16-2003 05:18:41
Definitely a wartime B, the serial number plate was tin, mine is a 42, the number plate is unreadable, six speed, no electrics(deleted due to the war), angle iron frame, with heavy plate between the frame rails right behind the radiator. john in ne.
Will P
02-16-2003 07:20:34
 Re: Re: Help me date my B??? in reply to John Ne., 02-16-2003 05:18:41
First, you could get electric during the war. Hard to find, but you could. I have to disagree, not war. To many things pointing to not.
Will P
43A
43B
49G
Will P
02-15-2003 22:43:38
Well, With 1 3/8" pto, angle iron frame, that would be 45, 46 or very early 47. Just out of curiosity. How many holes are on your tractors seat? Some early B's where converted to 1 3/8" pto. And the 39-very early 43 B's had the same angle iron frame as the 45-47 B's. But with 6 speed, it is at-least a 41-early 43.
Will P
bman
02-15-2003 20:32:57
does it have the heavey cast fram or the angle iron frame? batterysif so where? front wheels are off a 39.if it has a heavey piece of cast between fram rails it is a war time b 42 to mid 45.
Will P
02-16-2003 07:23:19
 Re: Re: Help me date my B??? in reply to bman, 02-15-2003 20:32:57
Early 43 and all of 44. Not any of 45.
Will P
43A
43B
49G
Rich
02-15-2003 18:22:57
Denny, try this site.....might be helpful, Good Luck, Rich
http://www.shaysnet.com/~rainbow/Partchanges.html
rla
02-15-2003 17:59:25
45 would be in the ball park, its 6 speed?
41/45 maybe.
Denny Foster
02-15-2003 20:55:02
 Re: Re: Help me date my B??? in reply to rla, 02-15-2003 17:59:25
It is a six speed has the high low shifter, the frame appears to be angle iron.
Denny
