Carpenter, an occasional knock is not the usual sign of a loose flywheel.. Once those things start knocking they usually are pretty constant. There are certain things that will aggravate the knock or make it worse. the clutch snapped out will usually make it worse, low RPM's will usually make it worse, heavy power pulses will usually make it worse... ~You do seem to have a lot of crankshaft end play & maybe you are hearing that pound a little [the end play should be .005"-.010"] 1/8" is .125" so that is getting quite excessive.. ~If those flywheel bolts were replaced with hardened bolts & torqued to 300' lbs that tells you that someone had a problem in that area at one time. ~The other possibility is that the crankshaft thrust washer is worn or has crumbled & has fallen out [I hope not as that is a pretty big job to replace].. ~You really should at least re-set the crankshaft end play to around .005"-.010" to start & see if your noise gets better.. Just loosen the two flywheel pinch bolts, then unstake the big crankshaft nut & turn the nut in a little while pounding on the flywheel with a large wooden block or better yet a lead hammer. Either use a dial indicator between the flywheel & crankcase or just set the endplay lower until you can just barely feel the flywheel move [a very slight movement].. Make sure you check the end play with the flywheel rotated to a few different places.. ~Your knock could also be caused by a loose clutch driver on the clutch side. When you pull the clutch apart look for signs of a lose clutch driver to crankshaft [a common problem on those diesels].. ~If your clutch pulley drive gear has migrated on the pulley hub it can cause noises if it has moved off far enough to hit the PTO drive gear.. That will also effect clutch operation.. ~There are also some clutch fork over travel bolts inside the 1st reduction cover & if those are contacting the clutch fork too early or allowing the fork to contact them with clutch disengaged & the lever not pulled that can make a rattling noise.. [do a clutch fork stop bolt adjustment] ~You could even have a fuel injection problem..If you have a faulty injector you can get a pretty pronounced combustion knock if a lot of unburnt fuel ignites at once.. ~There are other things that can cause a knock, like loose wrist pins, loose bearings, excess piston to bore wear, high carbon build up, incorrect fuel.. ~Your 730 should have the later better timing gears in it but even the late gears wear & can get kind of loud a times.. There are a lot of gears in the cam & pump timing gear train & those can knock when worn or loose [especially the idler gear].. ~If you have the flywheel cover off you might want to put a dab of finger nail polish or other hard & brittle paint on the flywheel to crankshaft nut & nut to crankshaft interface,, then run it a while.. If the paint has a broken line or signs of movement are noted you have a loose flywheel. ~You ask..."Does the excessive end play of the flywheel effect clutch operation or adjustment and does the clutch adjustment or engagement effect flywheel end play?"...>>> Answ, excess flywheel end play usually doesn't effect clutch operation but if excessive it could allow the crank to move too far & slow down or effect the clutch engagement as the crankshaft will move latterly as the clutch is engaged. .. Clutch adjustment has nothing to do with crankshaft end play.. ~As far as clutch comments go... post back when you get it apart & we'll go over a whole list of things to look for & look out for.. There are many wear areas in the clutch actuating mechanism. Some are just annoying & others really effect the clutch operation.. ~You might also want to put CLUTCH in the "search for" box at the top of the first page here & read till your eyes get tired.. You might want to edit the search by clicking [Sort by date (newest first)],, that will bring up the more recent posts... [email protected]
