Another plow question
ff316
02-14-2003 11:43:12
What's the deal with "slatted" moldboards? I would guess they are used in clay and sticky soil types. How wrong am I? Thanks! Fireman
Bob-Wyo
02-14-2003 19:32:42
 Re: Another plow question in reply to ff316, 02-14-2003 11:43:12
ff316 I have a 2 bottom and was told they were for breaking out sod fields.Maybe they should be called sod busters. lol. Have no idea if this is true or not but!!!!
SamH
02-14-2003 19:30:43
You're right, slat moldboards are designed to use in sticky soils. It's just a simple matter of less surface area for the soil to stick to. I've seen lots of horse drawn slats and the last one I remember was an IH that a neighbor bought sometime in the 70's.
MIKE HANLEY
02-14-2003 18:18:45
I wonder when the slat bottom came out. I rcall seeing them when I was a kid. But while I had out the old text book (Printed in 1955) that I quoted from in the posts on the disc plow, slat bottoms are not covered at all. It says, To design a plow which will perform satisfactorily in all soil conditions is a big proublem that has neverbeen entirly solved. Friction will be greatest at the point of share and gradually decrease backwards to the end of the moldboard. This can be seen on any plow bottom after considerable use. The greatest amount of wear is found to be at that point. gradually decreases backward to the tip of the wing of the moldboard. It then goes into the curvature of the moldboard differance between the stubble the general purpose and the blackland plow. and then the "NEW" (remember this is a 1955 book) high speed bottoms. speed bottoms. No mention of the slat bottom. NOW CAN I GO TO THE PROM? It is Valentines Day.
John T
02-14-2003 14:11:14
Hey Fireman, I sure wont say you're wrong, Ive used several of them, liked and had good luck with them, and imagined at least lol, they did pull easier. I was told that they reduce friction (drag of pulling them against and through soil) since theres less steel to soil surface area due to the empty (no moldboard) spaces. I pulled them mostly in clay (I never had enough money to own any any good dark or sandy soil lol) but liked every one I owned. Good Luck n God Bless Ol John T Nordhoff in Indiana
