4020 Motor
Jack
02-13-2003 05:05:16
Will a 4020 motor fit in a 4010 tractor without much work.Mine needs a crank ...so I bought a 4020 motor to take its place.If it won't will the crank fit into the 4010 block? Thus is my first change out on something like this.Can someone help me? Thanks for the reply in advance....
Jack
02-14-2003 05:05:53
 Re: 4020 Motor in reply to Jack, 02-13-2003 05:05:16
I will get my tape out and do so measuring..Thanks for so many replys..... ....Jack
newgen
02-13-2003 19:35:32
These guys are right Jack--sorry about the wrong info-I just had a stupid attack--
Alan F.
02-13-2003 17:29:56
Just sitting here reading this and something comes to mind..... uh I think it is a 4000!!!!
WTW
02-13-2003 10:00:09
It will fit in. The amount of alteration involved will be determined on how old your 4010 is and how new the 4020 engine is. The 4020 engine does have four holes in block where the frame rail bolts to at the front of the block verses two in your 4010 but I think the original two holes in the 4010 frame will line up to two of the four in the 4020 block. Get your tape measure out and check it other than that it will bolt up front and back. I usually just put 4020 frame rails in when I swap these as it is allot stronger especially for loader applications. Good Luck Dave W.
WTW
02-13-2003 09:59:09
JD70Jim
02-13-2003 07:00:09
If you do an overhaul on the 6380 engine in the 4010, you get the bigger 4020 sleeves and pistons. Once the bigger sleeves and pistons are installed, it IS a 4020 engine.
mike
02-13-2003 06:30:59
The story I got on this swap depends on how new of a 4020 engine you have I was told the late model engine uses a different size center hole onthe flywheel. you'll have to have it bored out, this may be BS but it is what I have been told.
newgen
02-13-2003 06:00:10
It will bolt right in with no modifications whatsoever.
Scott
02-13-2003 05:27:08
I haven't acutally put a 4020 motor in a 4010, but I have put a 55 series 466 cu in motor in a 4010 and it was very little trouble. Don't think you will have a big problem putting any of the small block deere motors in a 4010.
