DuAl Loaders
Woody (NE)
02-12-2003 19:49:03
What are the differences between the DuAl 250, 300 and 325 loaders? How do they compare with the Farmhand F11? Is there a site on the web with specifications? I am thinking of mounting a loader on my 620. Thanks.
AlbertoV05
02-15-2003 10:33:59
 Re: DuAl Loaders in reply to Woody (NE), 02-12-2003 19:49:03
Is DuAl still in business? If so, does anyone have a link to their website?
Thanks
Al in Iowa
Doc
02-14-2003 15:33:49
Hey Woody... I put a 250 on my A last summer. Works great. If you're doing heavy work you may want a 325, but that'd be really heavy work. The 250 is great for working in the trees, or medium dirt work. Bolts right on to the JD mounting pads. Mines got a farmhand pump, which is really strong.
Email if I can be of assistance...
Doc from Omaha
Larry W.
02-13-2003 05:30:13
I think the numbering system was/is a series of models and sizes/capacities. The 325 is a good heavy built loader. Du-All use heavier steel than farmhand, but a lot of people around here say it is low tensile steel and bends easier than the higher tensile steel used in Farmhand and John Deere brand loader frames. I have seen a lot of old loaders, and the Du-all seems to hold up as well as any of them.
Mel
02-12-2003 21:43:30
The 325 is the better of the 3 Duals that you listed. I have a 345 Dual on my 620 and it works great. I use it for a lot of dirt work around homes I construct and I haven't been able to crack anything yet. I had a Farmhand F-11 on it before. It lifted higher but sure sounded like it was breaking apart when you hit a dirt pile with it. It had to be welded up every year .
steve II JD4000
02-12-2003 20:16:48
third party image
I am't sure what # my is but I have picture what it looks like.. it comes off and put on easy.
Mike J
02-13-2003 06:02:33
 Re: Re: DuAl Loaders in reply to steve II JD4000, 02-12-2003 20:16:48
Steve your loader on your tractor is a model 3000 they are all good loaders the 250 is the loader that first came out when all that we had were 2 cylinder John Deere and M&H farmalls they stand up really well when fitted to the tractor they were made for.
