post hole digger use and sandy soil questions
Cormac
11-09-2005 02:39:40
In a few weeks I plan to use my post hole digger for the first time. I have a couple of questions? I plan to use 2 7/8", 3 1/2". and 4 1/2" OD pipe. For 4.5" post is my 9" auger acceptable or should I also invest in a 12" auger? I will use concrete to secure. Another question arose when a neighbor recently had someone dig some post holes for him. I looked at them the next day and they were 3/4 of the way full with loose soil. As I type this I am recalling that there was very little soil on the perimeter of the hole, so could he have just left it in there to prevent the sides from caving in? In any event, please offer some guidance for a novice post hole digger on use and when dealing with sandy soil. Thanks
John Schneider
11-09-2005 10:04:25
 Re: post hole digger use and sandy soil questions in reply to Cormac, 11-09-2005 02:39:40
Well...for what its worth, we have the same type of soil and putting in posts was a little tricky. Honestly, you might be better off without the concrete if you can't get a big enough hole dug and clear of the loose soil.? I drilled a smaller hole than what I needed and then simply drove the slightly larger post into the hole with a sledge. It went quickly and solidly with undisturbed soil around it for support. Don't know if this will help you or not.
