3 point trailer hitch
justplainjim
11-07-2005 14:57:29
can someone point me to the folks who make trailer hitches for a tractor 3 point hitch?
interested in using a 2 inch receiver and a 2 5/16 gooseneck.
thanks,
grub0927
11-11-2005 15:58:03
 Re: 3 point trailer hitch in reply to justplainjim, 11-07-2005 14:57:29
I just made one from an old Hidden Hitch from the junkyard. Cut off the hangers, turned down the shanks on two hitch pins I bought at the farm supply and welded them on the ends. I added a 16" riser for the top link and then welded a 1 7/8" and 2" ball on each side of the stinger. I use it everyday as I seem to move crap on trailers alot and it is much easier to manuver the tractor than a crewcab pickup.
I can drop the ball under the trailer hitch and lift the 3pt and I"m off.
Didn"t think I would be this happy w/ it but it"s one of those things you"ll wonder how you did without. Best 20 bucks I"ve spent lately.
Grub
john in ohio
11-07-2005 16:26:42
I just got one tonight from agri supply. it has goose neck hitch and a 2 inch reciever.
www.agri-supply.com or 1-800-345-0169
Ron in AR
11-07-2005 16:26:33
Try this one. There are others out there too. You just have to do a search.
Rod in Smiths Falls, ON,
11-07-2005 15:06:02
If you have a drawbar as well as the 3 pt hitch, all you need to do is weld a 2 1/2" square piece onto it and drill a horizontal 3/4 hole for the receiver pin.
