dearborn moldboard slat 2 bottom plow
fangtooth
11-04-2005 23:52:06
hello helpful ones i just bought a dearborn 2 bottom in what looks like to be i real good shape being a new tractor owner(8n) i'm learning what all the implements are used for this plow has only a trailing wheel of metal is there suppose to be leading disc or wheel in front of the two moldboards thanx
NEsota
11-07-2005 19:07:56
 Re: dearborn moldboard slat 2 bottom plow in reply to fangtooth, 11-04-2005 23:52:06
I would think that when sold new, at least in the Midwest, all these plows would have come equipped with the disks in front. Think they are called coulters. They were meant to cut the thrash or crop residue laying on top of the ground so it would not bunch up. Also cutting into the soil, made it a little easier for the tip of the plow lay to peal the dirt over. It was not uncommon to take them off and never use them again when they reached the point where they needed maintenance or for them to be barrowed by another plow and never returned. Under some field conditions coulters are quite beneficial and under others not having them would make little difference.
OH Boy
11-07-2005 18:50:56
Are you referring to the coulters? They are little metal slicing wheels that ride in front of each plow bottom, supposed to cut the sod and weeds to make it easier to plow. Most guys take them off as they can tend to get plugged up with weeds and vegetation.
OH Boy
11-07-2005 18:49:33
