John Deere Cutter/Conditioner 1209
TomTX
11-04-2005 12:28:46
Auction tomorrow (Sat) morning. Need advice. John Deere Mower-conditioner Model 1209, Serial No. 299481E. Looks like about 9 foot cut. Looks to be in average condition. Rubber rollers look a little worn, but very good. Good points/ Bad points. Year made. What to look for? How difficult to refurbish cycle bar, teeth, etc? What do they sell for?
Thanks in advance for your help.
Tom
Roger in Iowa
11-04-2005 18:50:15
 Re: John Deere Cutter/Conditioner 1209 in reply to TomTX, 11-04-2005 12:28:46
Ones with black reel are later versions. Make sure rubber (urethane) is not peeling off of rolls. Check wobble box mounting for cracks, knife heads can be worn but replaceable. Other good comments about seal leakages.
Make sure it has the hitch extension (equal angle)you will like it for corners. Nothing better.
roger
Errin OH
11-04-2005 15:32:43
Generally sell for less than a NH but work as well. Can't really think of one. Don't know. Seal leaks, play in gear box, peeling rubber. Depends. Here $1500-2500.
I been very happy with mine. Do look for signs the seals are bad and check fuild levels if you can. It doesn't take long to trash a very expensive gear box if it runs dry. Plus see if the hitch is with it (equal angel).
