landscaping equipment
Tom R
11-01-2005 08:10:03
I built a vacation home on reclaimed strip mining ground--nothing but clay and rocks. The rocks vary from pebbles to basket ball size. What kind of implements do I need to buy for my old Ford tractor to break up and smoothe the ground enough to plant a lawn (in the spring)? Has anyone got what I need for sale in central or SW Indiana?
Kevin (FL)
11-04-2005 12:52:21
 Re: landscaping equipment in reply to Tom R, 11-01-2005 08:10:03
Tom,
I'll weigh in with this: You need a box blade with the ripper teeth set as deep as possible (but not the blade) to drag the large rocks out and begin breaking up the clay. Once you get the big rocks piled up somewhere, then you might try a disc harrow to dig a little deeper and turn the soil/rock mixture, then get a landscape rake (also known as a rock rake) to clear out the smaller rocks and other debris. Don't know the HP of you Ford but a 5' disc, a 5' box blade and a 6' rake would be about the size you'll probably be able to pull....
