MM 2 bottom plow
Jim Lockhart
10-30-2005 18:34:32
Buddy gave me a MM 2 bottom trip,as far as I can tell all it needs is what I would call the "crazy wheel".Does anyone know a good place to get one.This is on rubber and from what I have been able to find out about it,the crazy wheel has a Rubber ring instead of a air up tire.Is this true?
Leroy
11-01-2005 04:08:39
 Re: MM 2 bottom plow in reply to Jim Lockhart, 10-30-2005 18:34:32
My MM 2-14" hydrolic lift has a air tire and so did the MM 3-14" clutch lift I used to have. Nexer seen or heard of a plow with a solid rubber tire. A wore out 4:80X12" boat trailer tire is a good one to use on that plow and most 12" plow tail wheels are the same and will bolt up to most other makes as long as you have the hub.
