slippage in 630 CASE
wide axle
10-30-2005 05:55:19
Well, I found the problem in my Case 630. YOu remember that it was slippng on take off. Well I drained the oil from the trans. and found the bottom gear stripped 3 teeth. I guess this is the problem. I found a guy that use to work in a small engine shop that said he could tear it down for a litle of nothing. He is suppose to start tomorrow night. I am so relieved that I don't have to "split" the tractor and put a clutch in. That woould be monumental I am sure. Well I will let you all know how it goes. I appreciate all your help even though it doesn't seem to be what you all said it was. Also, the oil seemed to be a little black, I guess that is where the burnt smell was coming from.
