Moline plow
Philmar Farms
10-29-2005 15:56:28
I just picked up a Moline plow. It is a two bottom 14 inch on steel wheels. How do you determine the model? The moldboards have Prairie Gold paint and a MM logo and seem to be newer then the rest of the plow. What would an orginal color scheme look like?
Philmar Farms
10-31-2005 14:28:41
 Re: Moline plow in reply to Philmar Farms, 10-29-2005 15:56:28
Thanks for all the info. This plow must be a low clearance,the points are 3" off the ground. I found a few part numbers:lower landside to moldboard bracket hf1382,tail wheel hub v5880. It is missing one adjusting handle, one landside and the casting on the end. The three coil springs are pretty bad but are there for samples. Are there points,landsides etc.availible?
edchainsaw
10-29-2005 19:02:15
ours was all red -- yellow wheels..
