Massey Harris #6 Mower
Ken from Ontari
10-26-2005 17:54:32
Took the cover off the back end of the mower and removed the chain to replace a broken gear. I replaced the gear but now can't get the chain connected. Need about a 1/4" of play to get the connecting link that it will go into both ends of the chain. How do you get adjustment to loosen or tighten the chain on these mowers?
I notice there are vertical slots on the front of the chain case. I removed all the bolts from the slots and tried moving the housing up and down, but still can't get the adjustment i need. Any one had experience with these mowers that can give me some advise. Thanks in advance for any replies.
Michael Soldan
10-27-2005 05:46:19
 Re: Massey Harris #6 Mower in reply to Ken from Ontario, 10-26-2005 17:54:32
Ken, sometimes you have to start with the gear off, slip the chain on the gear and then slid the gear onto the shaft, I don't know if you have room to try that, but I sense that it is the same chain and the same size gear that was on before so it should go back in. I' am not familiar with the mower but its the only thing I can think of, hope it helps, good luck..Mike in Exeter Ontario
