slow take off
wide axle
10-22-2005 09:21:04
Under heavy load(full load of hay bales on wagon) my old 630 case is slow to take off. I have to rev the engine and when I let out the clutch it finally takes hold if I let up on the throttle. If I put it in a lower gear it does not do it as bad. Does anyone know what could be the problem. I just changed the tansmission fluid not too long ago. The fuel filters have been changed in the last 6 months also. Any help will be appreciated. It did not do this til after I loaned it to a neighbor to plow a field this summer.
Cynicism Runs Rampant
10-22-2005 21:01:25
 Re: slow take off in reply to wide axle, 10-22-2005 09:21:04
Yup, your "friend" and "good neighbour" toasted the clutch, bet he will be right back this next spring wanting to borrow it all over again.
Bet you also, he was all laughing and joking when he brought it back the first time, did you have to fill it with fuel when he was done with it?
old
10-22-2005 16:47:20
Let me guess itsa a case-a-matic right. If so what weight oil are you useing and did you let it warm up. They don't like to pull when cold. Also you sure it has enough oil and is the system clean any of those can cause you problems.
old
10-22-2005 16:47:00
BobMo
10-22-2005 10:46:58
Just from your decription I'd say the clutch is slipping.
wide axle
10-22-2005 19:42:42
 Re: slow take off in reply to BobMo, 10-22-2005 10:46:58
No it is not a caseomatic it is gear drive. I can smell something burning sometimes but don't see any smoke. Smells like when you leave the parking brake on in a pickup. I am thinking maybe one of the gears is stripping in the tansmission. I hate to think about tearing the gears down, that will be a big job I know. I think I will take the top off and look in it. Does anybody know what gear it would be? Would it be real obvious when I take the top off? Wikll a tans. out of a 430 fit in this 630? I have one that my friend gave me for parts. I used the seat on a Ford 4000 but could not get anything else to work. It looks like USA made tractors should be interchangeable but they are not all the same are they? I did take the radiator off a g allis and put it on a 35 MH combine once. That was real handy. I miss using the G though but the combine comes in handy when I need to do the beans. I guess it was a trade off. Can't do much cultivating with the combine though. Oh well, Maybe somebody can help me with the 630 slow take off. If you can that is great, if not I guess I will look in the transmission when I get time.
Mike (WA)
10-24-2005 12:26:43
 Re: slow take off in reply to wide axle, 10-22-2005 19:42:42
Transmission gears are generally an "all or nothing" thing- they just break, they don't slip. I agree with the others- its the clutch- the burning you smell is the clutch disc heating up from not being held tight to the flywheel by the pressure plate. The good news is, this is an easier (and less $$) fix than almost anything in the transmission. As to interchangability of parts between tractors, the 430 is considerably smaller than the 630, so few parts will interchange. Each tractor is designed to handle the horsepower it generates, so the components will usually be different between models.
Don-Wi
10-23-2005 07:01:14
Yup, it's the clutch. Our 1855 we bought last April (04) had the same simptoms, a soft clutch when pulling a full load onto the road, and once in a while out in the feild it would slip(plowing) and stop for a breif moment. Now it's in the shop getting a new clutch, pressuer plate, pto drive hub etc. Not all of this is clutch related, but the engine needs to be out to replace them. What happened on ours that it finally gave out, the tube the bearing rides on came loose and slid w/, instead of staying pressed into the casting. That made it not dissengage properly.
Donovan from Wisconsin
Cactus farmer
10-22-2005 19:49:00
That burning is the clutch lining getting hot due to slippage. New clutch in order,me thinks....
Sounds like your neighbor rode the pedal while plowing. Burned it up I'm afraid.
paul
10-22-2005 20:18:25
 Re: slow take off in reply to Cactus farmer, 10-22-2005 19:49:00
His explination has to be about the funniest thing I've read on here in a long time. :) :) Made my evening. :) :)
Yea, it's the clutch plates, they are burned up. Split tractor, replace clutch.
--->Paul
jossette
10-22-2005 20:21:37
 Re: slow take off in reply to paul, 10-22-2005 20:18:25
Maybe starting in road gear wasnt the best???
( loaded or empty)))
