2-bottom plow
RDC
10-20-2005 18:49:13
Can anyone tell me how to setup my 2-bottom plow? The front plows does good but the back plow doesn't. I've tried different things but so far nothing has worked. Also what about the lift arm, are they suppose to be level or one side lower than the other. Any info. will be helpful. Thanks
msb
10-20-2005 19:18:43
 Re: 2-bottom plow in reply to RDC, 10-20-2005 18:49:13
Lift arm position depends upon the model of plow you have.Block up the left(land ) wheels depending upon the depth you want to plow.If that is 6 inches, use 6" boards to block up the left wheels.Then level the plow with the lift arms and center link.You will probably want to set the center link a wee bit long due to the tumbling action of a 3 point hitched plow.That should get you close.You may have to then fine tune the settings depending upon your ground conditions.
msb
10-20-2005 19:18:33
