Need advice on a 1980 MF 750 Combine
Beaglefarmerblue
10-19-2005 09:52:09
I went and looked at a 1980 MF 750 combine this past Monday. Everything looked real good. The machine looks very solid and runs great.
I did find two problems that jumped out at me. The first problem is a hydraulic leak on the cab side of the combine about half way back the combine. It looks like the main hydraulic pump for the system. The second problem is that the cab is sprung. Apparently the farmer that traded the machine hit a tree limb going down the road and bent the cab. There is a cable running from one corner of the cab to the corner of the hopper. Naturally, the cab door does not close properly.
The dealer is asking $4,500.00 for the machine with a 15' bean head. I think the cab issue makes the machine a piece of junk.
I can live with a bent cab for now, but I would like to price out what it would cost to replace the cab with a used one.
I was thinking of offering the dealer $2,000.00 for the machine. What do you guys think?
j meyer
10-19-2005 21:00:49
 Re: Need advice on a 1980 MF 750 Combine in reply to Beaglefarmerblue, 10-19-2005 09:52:09
Sir- I would recommend running! Totally mill of the run unit, higher hours on that expensive Perkins engine, and a sprung cab? Why are you considering? Total dime a dozen unit, there are better, I am certain of that!
RickL
10-19-2005 16:51:30
I wouldn't give anything for that unit period. I kniow where therr is Massey unit like you are talking about for 1500.00 if that would help and it is sitting in the shed
Beaglefarmerblue
10-19-2005 09:53:44
The combine has 3490 hours.
KRUSS
10-19-2005 14:43:35
 Re: Need advice on a 1980 MF 750 Combine in reply to Beaglefarmerblue, 10-19-2005 09:53:44
I have read where you were talking about this combine before. Up here in grain country (Manitoba Canada) very few 750 Massey's ever made that many hours before ending up at a wreckers. Having said that, many smaller acreage farmers have done well with them because the wreckers had lots of cheap parts.
Jay (ND)
10-19-2005 15:42:00
 Re: Need advice on a 1980 MF 750 Combine in reply to KRUSS, 10-19-2005 14:43:35
I agree - for this area up here, that price is high. It may be way different there.
