Howard Rotavator
Rich Keller
10-18-2005 05:27:39
I need some help from one of the Howard fans here at YT. I read through all the old posts trying to help myself, but I still have a list of questions. I have a HR that looks 60-ish. I cannot find a model no. It was made here in the states. The trans housing has cast letters that say model, but I cannot find a stamped letter or number series in the casting. there is a tag on the front trans cover behind the clutch but I can't find any print or engraving. May be unrelated. It says select-a-tilth. It looks 8'wide it has 8 tine hubs. It works. I just don't have a big enough horse. It has been the victum of "farmer engineering" at some time in it's life. I extended the carry arms 6" to get running clearance for the tumble stick, but 3/4" plate ain't enough to carry the old girl, and I need to correct the pitch angel.
I bought the tiller "barginday".When I first drug it home,I had a piece of field disced and the original launch showed promise. In loose material this thing will shred anything. I could not hold the travel speed. We are marginal farmers. My big tractor is a MM Jet star 3 that's really tired. I figure it's 45 hp. I'm assuming I'm underpowered. The low range in the jet star is obviously not a straight gear reduction like those described in some of the posts I read. When I got the extension arms welded on the second voyage was somewhat disappointing. I did get the shaft lenght right. the pitch of the arms needs to be adjusted to allow me to carry the unit higher off the surface. At the moment my draft drops at the bottom of the range and alows the tiller to full depth.This kills the engine. I read about the possibility of adjusting the the slip bolts on the clutch.Not sure this might not help, I'm sure the clutch is frozen at this point. I also read and thought before that maybe I could finesse a 2or 3" cut and make several passes to get to full depth. Problem is, I can't hold the wieght at the bottom of the hydraulic. It's not in the lift cause she'll hold the weight 10" off the ground, all day. I've got the lift point to low. In any case, in unbroken earth, the tiller pushes the tractor too fast or kills the engine if you try to hold the tractor with the brake and engage any depth.
I'm hoping one of you guys can offer some advice on a couple of questions. 1.) Is there anywhere else to look for a model number? 2.) Does anybody have a book or how to get to one? 3.) are the follower wheels supposed to be fixed or "stopped"? mine travel up and down along the slides. I'm thinking some of my depth control may be connected to the lack of some axel action that the wheels are supposed to provide? Maybe not. 4.) I'm sure my tines are worn out. I don't have any idea what they looked like new. Would new tines help me with depth? or hurt? 5.) Does anyone have an economical source for tines? 6.) If I removed say, two rows of tines to reduce effort needed, does anyone think I can slow this mother down and get it to till with my Jetstar? 7.)Any advice on how to go about freeing and setting the proper adjustment on the clutch? 8.) I'm thinking I will eventually try to hunt a Case 930 or 1030 to handel this beast. 9.) Does anyone have a photo of the upper structure of the factory three point set up they could send? My upper three point is a colage of shop scrap that has not performed as hoped by the original fabricator.
Basically, I need help. Any and all information would be appreciated. I would love to get this thing to work as I know it can. I just don't have any idea what it looked like when it was complete, what's missing, or how to set it up for proper operation. Thanks
Steve Mundy
11-04-2005 19:27:45
 Re: Howard Rotavator in reply to Rich Keller, 10-18-2005 05:27:39
I can likely identify your Howard Rotavator. Can you find any casting numbers on the gearbox or cover plates. Is the machine side drive a chain or gears? What type of depth control does it have?
Steve
Howard USA
Bloomington, IL
Phone 309-820-1090 Ext. 110
Robert in W. Mi.
10-20-2005 17:19:03
third party image
First off "HR" is only half of the model designation. For instance, it could be an HR20?? HR30??, HR40?? or any of several others....
For a rotavator eight feet wide, you need 80 plus pto hp for it!!! More will be better!
"Select-a-tilth" means you have a multi speed gear box on it!! This is good! It also means you can change the rotor speed by switching the gears around inside the gear box. The back cover comes off and you change the gears around to change the speed. Putting it on the LOWEST rotor speed will take LESS power to run it!
"If" it has side wheels, these are what you ajust up and down to ajust tiller depth.
Normally HR models have 6 tines per flange. There are holes for more, but 6 is the normal number. Also they are bolted on there in a pattern, not random... You can take some off and it will take less power to run it, but 45 pto hp just isn't enough for this rotavator!!
I use my 6 foot Howard with my AGCO 45 pto hp tractor and do a LOT of custom rotavateing with it. I've made more $$ with this combo than with any of the 3 rotavators i own. It works very well...
Here's a pict of my HR30 80" that also got plenty of use this summer...
Robert
Rich Keller
10-21-2005 18:19:51
 Re: Howard Rotavator in reply to Robert in W. Mi., 10-20-2005 17:19:03
Robert, thanks for the comeback. I"m up to ears atthe moment with closing out a job and trying to get ready for Christmas tree sales. But I am hopimg I can change the gears and maybe remove a couple of rows of tines to get this thimg up and running before spring. We"re in the appalachians we usually have snow on the ground once or twice by now,point being I have an outdoor garage. Plenty of ceiling room, hard to heat. If you have the time to provide any guidance on the gear change I may find the time to open this thing up. I am also at a loss as to how the guage wheels would be fixed to the slides. Obviously, I"m missing something your photo seems to show hydraulic cylinders that operate your guage wheels . I have to assume I must have an early model. My buddy has a machine shop I"ll probably end up picking his brain for a guage wheel adjustment lock of some kind. I do thank you for the info andtaking the time to help. Rich
dave up of MI
10-21-2005 19:58:04
 Re: Howard Rotavator in reply to Rich Keller, 10-21-2005 18:19:51
I would like to add a few things about running a 3 pt tiller. First off I did get my tips from a large dealer in Ill. somewhere. I run a 84" tiller on my 70hp tractor just fine. I couple of things I might try for your cause. You do not have enough power to run this tiller. If you start taking off tines take off all on the flange and sides. Keep the unit balenced. I would start with a full set on each side at a time. Second if the unit has a drop gate ALWAYS run with the gate up. This is probally one of the best tips I have got.
Third Try to run your tiller in lowest tractor speed. See how it does.
Fourth Higher tine speed does not need more HP. I would have to double check mine on actual rate but I have a very high tine speed. This in combination with a slow tractor speed cuts down on the bite between blade strikes. And actually allows the tiller to work better. Now depending on how many rocks you have you may have to choose a different tractor speed.
Hope this helps Dave
Robert in W. Mi.
10-22-2005 06:56:22
 Re: Howard Rotavator in reply to dave up of MI, 10-21-2005 19:58:04
(Fourth Higher tine speed does not need more HP)
I'm not sure where you came to that conclusion, but think about it.....
Gearing "anything" higher requires more power to run it. I can put a rotavator in a field with a tractor that's a bit undersized for the rotavator. Then start changeing the gears in the gear box and you can watch the temp of the tractor go up every time i gear it up, to the point the tractor won't have enough power to run it without lugging.
The slowest tine speed requires less power.
This isn't BS, anyone can stop by my farm and i'll show them so they can see for themselves.
Opening the back door does take LESS power, but unless your in a garden or sand you may not like the job it does...
I rotavate comercially in a fifty mile radius around my farm, and i run into different conditions all the time. When you do this for a liveing for a few years you learn fast that different soil, moisture content ect.. changes everything.
A tiller in a sandy spot doesn't take much power, put that same tiller in a muck field with damp soil and you'll over heat that same tractor.
Personally, i believe the origional poster has "too small of a tractor" and all he's going to do is trash it trying to make it work with this rotavator.
Robert
dave up of mi
10-22-2005 18:09:07
 Re: Howard Rotavator in reply to Robert in W. Mi., 10-22-2005 06:56:22
Well I do think you have lots of time on a tiller as well as I do. HOWEVER when you put a tiller in a higher gear with the tiller raised it takes no more HP than a low speed.
NOW with that said I till with a CASE 770. It has a power shift with 3 gears per each fixed gear. I this case [no pun intended] I can keep the tractor speed low with the tiller speed high. This will let the tiller cut better, and will not use any more HP than running your tiller with a faster tractor gear with lower tiller speed.
I have tilled MANY fields in this fasion. ALL I tried to do, was to let him know that he might have an option to raise the tiller speed keep the tractor slow and he may be able to swing that tiller on his tractor.
Dave
Robert in W. Mi.
10-23-2005 07:06:28
 Re: Howard Rotavator in reply to dave up of mi, 10-22-2005 18:09:07
Thanks Dave,
I think what "i" missed in your post was, your compareing two different ground speeds along with two different rotor speeds and depths.
Anyway, i hear you guys in the UP grow potatoes that are hard as rocks!! I knew a guy one time that spent some time up there in the "crow bar motel" and that's what he was telling me.
Next time your headed to lower Mi. send me an email and stop by, we can solve all our rotavator problems.... :>)
Robert
dave up of MI
10-23-2005 12:07:51
 Re: Howard Rotavator in reply to Robert in W. Mi., 10-23-2005 07:06:28
Sounds good. I love the tiller. In fact I sold my disc this year. I do not have much in rocks here except for one of the parcels I work. But the tiller still works great. Nothing give you a ready to plant job like the tiller.
Dave
Rich Keller
10-21-2005 18:14:55
Robert in W. Mi.
10-22-2005 07:10:02
 Re: Howard Rotavator in reply to Rich Keller, 10-21-2005 18:14:55
third party image
Howard used several different designs for ajusting the depth of there rotavators. Mine does NOT use hydraulic cylinders, it uses what "looks like" a screw jack to ajust them. You turn the crank on top, and the guage wheels go up or down...
Here's a pict. of the gear box on my HR30 "open".
Robert
rich keller
10-22-2005 08:33:45
 Re: Howard Rotavator in reply to Robert in W. Mi., 10-22-2005 07:10:02
Robert, thanks for the gear box photo. Expert opinion and contientious effort to help, is always appreciated. Combative, officious dismisal of opposing points of view are not. Facts is facts, no disputing your point.
I"ve done my time in the machine shop long enough to know when I"m asking for everthimg iron can give on the margins. I asked for help and some good souls tried. The attitude that reads through is counter productive to the spirit here at YT in my experience.
Who cares if your the smartest guy that ever sat on a tractor, if nobody wants to talk to you because you sound like a know it all? Long before I learned to understand steel, I learned how to be courteous.
The smartest guys I ever learned anything from were, to a man, sharp, kind, and courteous to "less informed". Ignorance ain't a sin. Education cures it. I don't know about arrogance. Wisdom is not a weapon, it"s a gift. It ain"t worth nothin" until you give it away! Thanks for your contribution. Here's mine.
rich keller
10-22-2005 08:32:59
Hayfarmer
10-18-2005 19:19:41
When I was in high school our FFA chapter had a rototiller, think it was Howard but maybe Northwest. Anyway we did gardens in the spring and new lawns and occasionally a field. Ours was a 4 foot I think, we had a MF 35 and later a 135, both about 35 hp. Was all it wanted to handle in loose ground and on sod you had to just hit the top then go over again. My area has rocks in many places, on those we would go over the first time running tiller with tractor throttled down. The property owner would pick the rocks up and we would go deeper on the next pass. I once put in a lawn and dug up most of a bicycle and wrapped a set of tire chains around the shaft. I would think the 45 HP is way too low for an 8 foot. You might try taking some of the tines off.
Bill in NorthCentral PA
10-18-2005 05:51:50
I have one that works great. They are a beast of a machine. I do remove tines to allow for narrower tilled areas, and it seems to not be a problem - definitely takes less power. The tines are "L" shaped on mine. If you reinstall tines, use new grade 8, fine trhead bolts. The old ones just disappear. I'll try to post a picture of the front when I get a chance. (And if I can figure it out - I haven't done it before.) I usually find runnind two passes makes it much easier on the machinery. I adjust the depth wheel / slide so that the weight of the machine is on these, not the hydraulics.
Good luck,
Bill
Rich Keller
10-19-2005 06:10:40
 Re: Howard Rotavator in reply to Bill in NorthCentral PA, 10-18-2005 05:51:50
Bill, a photo of the upper three point would be great. I could also use a photo of the wheel adjustment mechanism, my HR doesn"t have any. Thanks Rich
deep creek farmer
10-18-2005 06:16:45
I have a howard 6" rotovator. I agree with everything Bill said. I have found that I nead at least 75 hp on mine to do a good job. I usually use 90 hp. If yours is 8" you need way more hp. Scott
