 To set up your plow, a manual always comes in handy. There are different ways for different models, but the end result has to be the same. When the plow is straight behind the tractor, the first plaow share has to be taking a full width of cut, either 14, 16, or 18", which ever size bottom is on it. It's easiest to tell if you have some loose soil around that your tires leave and imprint, then set the plow down and get out the tape measure. I got lucky w/ our 546 I bought, it was already set where I needed it for the 1855. On our 565 plow, there is a long threaded rod you're supposed to turn to adjust the plow to where it's taking a proper size cut. Ours is rusted right tight, so when we got the 1755 which was narrowed up for cultivating and to fit behind the bucket, we took the hitch bar and moved it over to work. That plow had major issues staying in the ground, but it got better after replacing all of the wear parts. Still has some issues, but the steering needs to be taken apart and bushed up. As far as ajusting it in the feild after taking your first pass on-land, I've never worried about it. I set it up once I take the first round just to make sure it's level, but after that I just go, doing one feild after the other, and splitting them up as I go. As far as what way you need to go, ussually you alternate going clockwise around the middle, and going CCW on the outside, other wise you'll end up with very deep and large dead furrows if you put them in the same spot every year. Basically making a ditch. By alternating, it gives you a low spot to start out in, so it's not completly on land as you are in last years furrow. Clear as mud? Donoavn from Wisconsin
