plowing
huron
10-15-2005 13:20:09
I have a small piece of property (3acres) and I am going to buy a small farmall tractor to plant some gardens. What would be the best plow setup for a super c type machine. The hayfield has not been broken in 15 years,only mowed. Will I need a bottom plow and disc setup? I am new to this and could use some advice. I am thinking super c for the hydraulics and because implements are still readily available,besides I have a love affair for these machines. does the super c have a live pto?
Jimmy King
10-23-2005 15:17:31
 Re: plowing in reply to huron, 10-15-2005 13:20:09
A super C, 200, 230, or 100, 130 with fast hitch. Also a fast hitch disc because of the small area. That is easier to pick it up and set it down at the edges of the gardens.
Hugh MacKay
10-15-2005 15:45:56
huron: None of the smaller Farmalls ever had Live PTO. However if your into gardening the Super C or Super A type tractors are a good choice. I personally like the newer models with fast hitch. Makes it much faster for changing implements, yet keeps the mechanical engineering of older Farmalls.
edchainsaw
10-16-2005 15:47:59
 Re: plowing in reply to Hugh MacKay, 10-15-2005 15:45:56
the super C did not have live PTO but does have live hydralic power... nice fast hitch tools and easy to handle...
as to gardening--- you need the moldboard plow, disc and a harrow (maybe) and dont be scared to use them every year it will not hurt.
