Chopper Blades
pbutler
10-11-2005 10:42:59
Thread below about broken blades got me to thinking. I have an older set I replaced because they were completely dull. Now the newer set is getting dull as well-I have a lot of rough ground I mow.
Is it safe to grind them and put a new edge on them-or too risky to get them out of balance?
supergrumpy
10-14-2005 09:22:30
 Re: Chopper Blades in reply to pbutler, 10-11-2005 10:42:59
if you are talking about a bush hog type mower, I touch mine up in place with angle grinder, take about same amount off each one to keep it in balance
after a few touch-ups, I take the blades off and grind them good on bench grinder, use a good quality fishing scale to keep them weighing the same, sure not gonna wear the scale out with the fish I catch
when they get beat up real bad, I replace them as a set
