Massey #41 Sickle Mower
FordTractorMan
10-10-2005 19:29:39
Hi all. I've got a MF (that's what I'm calling it now) sickle mower that started smoking in the dyna-balance drive this afternoon. I greased 'er up right good before I started mowing and hadn't mowed too long till I smelled something. Took a look and saw smoke coming out of the 2 holes where you access the grease fittings on the back side of the drive. I checked in there and there wasn't any grass stuck. I rolled the pulley by hand and there seemed to be a good deal of play in the parts inside the gearbox. What's in there and can it be rebuilt without a bank loan? It doesn't look like a wobble box drive...
Thanks.
FTM
jossette
10-10-2005 20:23:18
 Re: Massey #41 Sickle Mower in reply to FordTractorMan, 10-10-2005 19:29:39
should have gotten a belt drive... If it smokes, just change the belt.. Gear box is probably low on oil and now parts. I like my moline belt, just has roller and needle bearings and your going again.....
FordTractorMan
10-10-2005 20:45:30
 Re: Massey #41 Sickle Mower in reply to jossette, 10-10-2005 20:23:18
It is a belt drive and the belt isn't smoking. It's coming from the dyna-balance or gearbox or whatever it's called where the sickle head bolts to what drives it. I've heard it called a gearbox and a dyna-balance I thought it was a wobble box like on a combine till I looked a little closer.
FTM
Tim(nj)
10-11-2005 18:29:11
 Re: Massey #41 Sickle Mower in reply to FordTractorMan, 10-10-2005 20:45:30
It is indeed the Dyna-Balance unit. MF used a crankshaft assembly to make a balanced-head mower drive instead of an eccentric wobble. Maybe a bearing has gone out, if that"s the case, then it shouldn"t be too bad to do the rebuild parts-wise. I"m not sure how well the #41 Dyna-Balance is supported by MF anymore. I know my #31, which has the earlier cast box instead of the welded one, doesn"t have much support. I was lucky enough to have found a mid-mount MF sickle mower with a damaged bar that had the same cast Dyna-Balance on it as my 31, so I have a spare if I ever need it.
jossette
10-11-2005 05:30:00
pitman crank assembly.
send me an e-mail I got pics....
Tim(nj)
10-12-2005 10:06:05
 Re: Massey #41 Sickle Mower in reply to jossette, 10-11-2005 05:30:00
There"s no pitman on an MF 41 Dynabalance. . . .
drost
05-24-2006 14:36:09
 Re: Massey #41 Sickle Mower in reply to Tim(nj), 10-12-2005 10:06:05
time to rebuild the gearbox.
