rotary cutter blades
Ricky V. Hopki
10-10-2005 16:00:04
Hello, I have broken a blade on my rotary cutter. The one looks good with very little wear. Should both blades be replaced or is it o.k. to replace the one. Thanks in advance. Rick
Jerry/MT
10-13-2005 12:19:15
 Re: rotary cutter blades in reply to Ricky V. Hopkins, 10-10-2005 16:00:04
Depends on what broke the blade! If it's fatigue from long time use or major wear fro long use, than replace them both. Rotary cutters are one of the most abused pieces of equipment on a farm or ranch and a blade failure while you are operating could have disasterous results. Be safe!
Robert in W. Mi.
10-10-2005 17:43:04
Personally, i'd weigh the new blade, and if it's pretty close to the same weight of the one you already have, i'd not worry about it..
Robert
Paul E
10-10-2005 16:21:14
I just replace whatevers broke/bent/not sharp. Anything else is good!!
