Planting Garlic
Rod in Smiths F
10-06-2005 19:37:26
It's time to plant several rows of garlic in the garden patch which is currently sown to oats as a mulch crop.
The instructions call for the cloves to be placed 4 to 5" deep and 6 to 8" apart.
Is there a simple implement to use with the tractor which will reduce the digging?
Chuck MI
10-07-2005 03:51:38
 Re: Planting Garlic in reply to Rod in Smiths Falls, ON, , 10-06-2005 19:37:26
third party image
Here's a dibbler that I built. It's pretty simple, yet took many hours to construct. I also made a hinged hitch on the back of a 3 point rototiller to eliminate a pass.
Basically it is a steel lawn roller with cubes made of 1/8" steel welded to the roller. I don't know if you can justify the time to make such a thing, but it saves alot of time and creates the perfect spacing every time.
Chuck
10-07-2005 05:13:04
 Re: Planting Garlic in reply to Chuck MI, 10-07-2005 03:51:38
That's a very interesting implement. From that am I to gather that you don't plant the cloves all that deeply?
I plan to plant a couple of thousand walnuts this fall -- a bigger project -- and wonder if something similar grafted to an old steel field-roller would make and mark the 20' grid we need.
Thanks for the picture. It explains a lot.
The well-drained seed bed for garlic is about 70' long and the ground was quite soft when I planted the oats two months ago. I've thought of making the holes with a long auger in a cordless drill, but that may be overkill.
10-07-2005 05:25:27
 Re: Planting Garlic in reply to Rod in Smiths Falls, ON, , 10-07-2005 05:13:04
Another question:
I see you use rows about 16" wide.
I'm planting the garlic next to a well-established row of asparagus.
With the oats planted and dying over the winter as a mulch crop, would there be any advantage to spacing the garlic rows so as to allow cultivation with my 28" rear-tine tiller? Or would a rectangular patch of garlic planted in several 12" rows be better?
Thanks,
Rod
Chuck MI
10-07-2005 09:08:14
 Re: Planting Garlic in reply to Rod in Smiths Falls, ON, , 10-07-2005 05:25:27
I built it fo rmy neighbor who does mixed veggies. Mostly plants 2" cubes with it, but there is no reason you couldn't make the dibbler longer if you want to go deeper. I personally know nothing of growing garlic. This is set on 12 inch rows with about 10 inches between plants in the row. He sometimes skips holes if he wants to increase the spacing (without building another dibbler.) If you want to us a rototiller for culitvation, I wouldn't plant it tight rows. If you have a suitable cultivator, you probably wouldn't be talking about the rototiller. Whatever you do you will most likely have to deal with weeds, so you should plan ahead.
If you have any other questions, let me know.
Chuck
John(OR)
10-06-2005 20:37:55
The boys around here grow alot of garlic seed (Central Oregon)and then it is shipped back to Calif to be grown again. The Calif boys come up and plant it for them and they use an implement that looks just like a drill if you would like will go talk to one or two of them tomorrow and get back to u. hey just finished harvest and have already planted back
