Hay Stacks
WyoDave
10-06-2005 09:55:54
I know there were some concerns about stacking hay outside and shedding water. Here are some pictures of how almost all hay is stacked in this region.
third party image
Stack End
third party image
Entire Stack
third party image
The machine that does it all. I hope this all helps.
BobMo
10-07-2005 07:55:58
 WyoDaveHay Stacks in reply to WyoDave, 10-06-2005 09:55:54
Dave, I know what you say about storage is correct but as some of us are aware where you get 36" of rain fall anually this won't work. I do have some questions about your pictures though because the bale wagon in the picture is the same as mine and doesn't stack on edge as your stacks are made.
When the bales enter the bale shute with this wagon they are on edge, go onto the 1st table flat, the second table on edge and the wagon flat. Your stacks were probably made by a bale wagon but not this one. I also don't think this wagon has the ability to the ties shown in rows 5 & 7.
Really nice pictures though and I have enjoyed these scenes many time traveling through western states to Alberta.
WyoDave
10-07-2005 08:11:28
 Re: WyoDaveHay Stacks in reply to BobMo, 10-07-2005 07:55:58
Well I know what you mean about differences in regions. That however is our balewagon and our stacks so I know that it made it. We use 1/4 turn chutes on our balers so the bales enter the baler standing on edge. Personally I never knew you could stack the other way and you probably never knew you could stack this way either. It also makes the tie and raincap layer just like in the picture.
David
WyoDave
10-07-2005 08:15:02
 Re: WyoDaveHay Stacks in reply to WyoDave, 10-07-2005 08:11:28
After rereading your post I see that your bales stack the same way as ours. When you set the entire stack up in place they are than on edge. Or are you not setting the entire stack up in one piece?
David
BobMo
10-07-2005 10:33:37
 Re: WyoDaveHay Stacks in reply to WyoDave, 10-07-2005 08:15:02
I use a 1/4-turn chute also so the bale is in the field on edge. It�s picked up by the bale wagon but turns in the bale chute and is delivered to the 1st table flat. It is the set on 2nd table on edge. As you know when the 2nd table is full it lifts onto the wagon. These are in the flat on the wagon and come off on edge as you describe. I must apologize for my pervious statement because my mind and fingers somehow became disconnected.
That being said my bale wagon sets behind the barn now in favor of an accumulator. In its case stacking flat is easier since the forks will not pick up bales on edge. Since I stack in a hay barn flat is the only way I can go with no manual labor. Good luck and I do like the pictures....
WyoDave
10-08-2005 07:41:45
 Re: WyoDaveHay Stacks in reply to BobMo, 10-07-2005 10:33:37
Alright. That is how ours works as well. Also these bales are lifted with grapples in groups of 8 or 12 right onto semi trailers on edge just as they are stacked. The semis are stacked on edge as well so I know that with the right set up you could stack on edge without handling. One man can load a 20 ton semi load in about 2 hrs. However I'm sure what you have is working well for you so no point in changing.
David
KIP in MX
10-06-2005 19:26:03
 Re: Hay Stacks in reply to WyoDave, 10-06-2005 09:55:54
How does your bale wagon do the 5th and 7th layers? We had neighbors in the 70�s with NH wagons, but I remember all the layers were the same. All of the hay in southern NM was alfalfa and wire tied then and we always stacked flat in barns. If it was outside, it got tarps even though it hardly rains there. Later, some guys bought those JD cubers and that was all piled outside.
WyoDave
10-07-2005 07:55:45
 Re: Hay Stacks in reply to KIP in MX, 10-06-2005 19:26:03
The fith layer is the tie layer. It helps hold the stack together. It puts 3 bales up on the second table like normal than kicks the middle one out. Than two spikes hold the corners to the bales on the edge. It than puts 3 sets of two bales between the outside ones and than finishes the layer like normal. This gives you two bales one on each side that are the opposite direction to the rest of the stack tieing the stack together. The 7th layer is just two bales wide which creates a raincap so all the spaces between the bales don't line up and rain can't run just straight through the stack. The balewagon is set up to automatically do this although you do have to start the tie layer manually.
David
wolfman
10-06-2005 16:43:17
Geeze, we get so much wet weather here in s.w.Pa that I cover round bales. A stack like that pictured would be pretty much waste here.
Dave H (MI)
10-06-2005 11:55:37
I'm curious. Does it go directly from summer to freezing winter in Wyoming? Around here we have a prolonged rainy fall season and come New Years you would need dynamite to get those apart once they was soaked and frozen. I didn't see any tarps in the pics. I was wondering how that works?
KEH
10-06-2005 14:53:14
 Re: Hay Stacks in reply to Dave H (MI), 10-06-2005 11:55:37
Dave, Sometime around 1971 we took a trip West. Ran across a man North of Laramie, WY stacking hay with the same equipment(older tractor) There was a stack left over from the previous year that looked about as good as new. It was a surprise to me too, being from wet SC. Not enough rain there to spoil the hay, probably less than a foot per year. Interestingly enough, the man had pulled the rake to the field with a Ford A Model coupe.
KEH
WyoDave
10-06-2005 16:28:58
 Re: Hay Stacks in reply to KEH, 10-06-2005 14:53:14
We don't get rain or snow or anything much. It also goes pretty much from summer to freezing. A couple days ago it was 89 degrees. Last night 21 degrees. We've had hay sit as long as two years that was still very feedable. We do tarp some high quality hay from time to time but by no means all of it.
David
Dave H (MI)
10-06-2005 16:58:09
 Re: Hay Stacks in reply to WyoDave, 10-06-2005 16:28:58
Wow! That is pretty amazing. You could sell it for compost after two years sitting out here! One year sitting out and it sprouts mushrooms.
Nice thing about the forums, you get to see how your neighbor four states over does it. Appreciate the education guys!
Sam (MO)
10-07-2005 12:33:48
 Re: Hay Stacks in reply to Dave H (MI), 10-06-2005 16:58:09
I got a NH 1034. I hope to have it up and running this fall so I can use it next summer. But here in MO it might not work since I don't have a barn tall enough to stack the hay. Here in Mo we can grow mushrooms in the same year if the hay is sitting outside.
