Offset brush hog
oliver_newb ie
10-04-2005 01:46:10
Offset Brush Hog
Looking to mow 1-1/2 miles of trail/road with 49 Ford 8N (20 hp). Mostly grass, some blackberry, some 3 mo old willows grow over this access road and like to keep it tidy. Right now it is a multi-day chore with a Stihl weed whacker (with brush blade) Ok to do some hand work but like to get the bulk with tractor.
What I think would be great is a brush hog type mower offset so it mowed 12 or 18 inches outside the rear tire. This would allow me to mow to the edge of the road, over the ditch, and in sunken areas right up to the wall. Cut the left side driving out; cut the right side driving home. Problem is I have never seen such an object�. And I�ve looked in the archives for both 8N and implements and a few google searches.
Q1 Am I missing something, is there an offset brush-hog (and less than a zillion dollars) Or perhaps a very short sickle bar mower. Don�t want the mower sticking 3 ft past the wheel.
Q2 Am I missing some critical bit of tractor operation (or more importantly safety) that makes this a terrible idea?
Q3 Is making such a creature a worse idea? A PTO gearbox, a transverse shaft to a right angle drive, all scaled for 25 hp, some blades. Whole assy mounted to a steel deck with bracing and lift points. Sure cost more to make than purchase but if it was the right thing may be worth it.
As always thanks in advance for your collective wisdom. PS I have posted in both Ford 8N and Imptlement Alley.
RWK in WI
10-04-2005 18:01:19
 Re: Offset brush hog in reply to oliver_newb ie, 10-04-2005 01:46:10
A possible suggestion is to get one of the self contained / self powered brush cutter mowers designed for use behind garden tractors or ATVs . They are about 5 foot cut and can be set off to the side as much as you want. I have seen grass cutters in the $1000 range and true brush cutters in the $1500 to $2000 range. I can't list possible suppliers or this will not post.
jhill
10-04-2005 14:00:23
I think alot of the flail mowers Mott, Ford ETC are made ofset like you want. One would work in light brush and grass.
dorset farmer
10-04-2005 09:19:13
Hardee, now EVH Manufacturing, may still make them. I planned to buy one 2 years ago & spoke to a factory representative. They were available in right or left hand off set. Instead, I paid to have mine converted my 5 ft bush hog to an off set. Cost me $600, but you could do it for much less if you're a welder. Also, Bush Hog makes an off set in a light duty bush hog- it is an SQ84t (84 inches wide), and has a 19 inch offset. Mike
Phil Roberson
10-04-2005 09:13:19
I have seen orchard mowers that look like they will do the trick, but I think they are too big, and probably too expensive. But I remember seeing mower decks with an extra set of blades on an arm that extended to the side. As I remember, the side mower was belt driven off the main cutter, and hinged about the axis of the belt pulleys. They had a big rubber wheel that allowed an orchard tree to push the mower out of the way, and springs to push it back once it was clear of the tree. Would proably work the same along fence lines. Seeing one for the first time was one of those "how about that" moments.
mlm
10-04-2005 08:22:00
do you happen to live neaqr Michigan? I have a Brillion with center blades and gearbox that also drives an offset gear box and blades. The center section shaft has been broken and removed but the offset section still works good. I would sell it cheap. I can't find a new shaft.
oliver_newbie
10-04-2005 12:43:23
 Re: Offset brush hog in reply to mlm, 10-04-2005 08:22:00
Alas I'm in WA.
Able
10-04-2005 06:47:21
Hardee Mfg. out of Loris SC use to make them. I still have one. But I use mine straight behind the tractor. Mine is a 6' cut on a 3 pth and I pull it with a JD 50 with no problems. It will offset about 18 to 20 inches. They were very popular in my area about 30 years ago. They also made smaller widths , your tractor should be able to handle a 5' model if you can locate one. Put out an ad.
BobMo
10-04-2005 06:25:36
Newbie, most major brush cutter manufactures make/did make offset brush cutters. They don't however make them for your little tractor simply because of the drive line. Most are 8 or 10 ft. models and require about 50+ hp. You can buy them at auctions if you keep an eye out for 1600-3000 for a decent one in this area.
I would suggest that you look at getting a pull type (offset) for use behind an atv from Northern Tool with its own motor. It may take a couple trips but it will be quick and if you cut it every 2 or 3 weeks simple. Good luck...
Fighting suburbia in NC
10-04-2005 05:34:58
I know there are some available from time past but finding one now might be the issue. I know of one that is hooked to an old IH ("M"?) that the owner uses for fence lines but I have no idea where he got or who made it. As I remember from seeing it several years ago the frame was shifted about 6" outside the wheel path but the driveline was run at an angle, if I recall correctly. I remember thinking "how do you keep a u-joint in it?" at the time but he says it worked like a charm.
I do not think I have ever seen another one since then, though.
Pete/ME
10-04-2005 03:02:58
They make offset rotary mowers for roadside mowing. One is just offset the width of the mower and raises with the 3pt. for about $8k, and and "Alamo" that tilts 90 degrees to mow sideways for about $15k (prices are what I remember)There are also ones that are flails on booms...super $$$. I've always wanted to make one. An old 5 footer, another right angle gear box and a counter weight, I'm just a a little short on welding skills, but by all means give it a try.
midalake
10-05-2005 09:13:50
 Re: Offset brush hog in reply to Pete/ME, 10-04-2005 03:02:58
Dont try to buy one of those ATV mowers they are junk. My buddy had one of the better ones and it fell apart. I have an old EL Cadwell and sons mower. 9ft off set. Runs on belts work great but I need to re-do the seals in the gear case they leak like a sive.
