Lawn Roller filler
Doug Medley
10-02-2005 18:12:43
Recently bought a fairly new lawn roller from my neighbor. It is a large one about 48"x24" painted steel. He had it filled with plain water. I am worried about rust from the inside, there is presently no visible rust on it. Is there any thing that I can put inside, aside from oil, to prevent it from rusting? I was thinking about RV anti-freezer but maybe there is something better.
Thanks,
Doug
bvomark
10-04-2005 06:10:11
 Re: Lawn Roller filler in reply to Doug Medley, 10-02-2005 18:12:43
You will have to drain the water every fall if you live where it gets below freezing. That is why I think antifreeze would be great.
Leland
10-03-2005 20:34:48
I have saw them filled with used motor oil and it's free at the right shop no rust worries .
RayP(MI)
10-03-2005 17:20:05
Consider used antifreeze from your local auto dealer/repair shop? Friend of mine built a 8 foot roller, (7,000 lbs) and filled it with used anitfreeze form a local car dealer. They were glad to get rid of it, and it should protect you from rust and freezing. If in doubt, throw in a gallon or two of new concentrate to bring up protection level.
JMS/MN
10-03-2005 18:10:11
 Re: Lawn Roller filler in reply to RayP(MI), 10-03-2005 17:20:05
I agree that car and truck shops are a good source of used antifreeze, along with construction companies. They usually have to pay to get rid of it, so they welcome people who take it. BUT- a roller 8 feet wide?, weighing 7000 lbs> what is the diameter, construction, etc.?
Gary The Rookie Farmer
10-03-2005 08:09:32
RV antifreeeze would be kind of expensive, if you go that route maybe try washer fluid instead?
Chuck MI
10-03-2005 03:38:49
Get it good and dry, and fill it with dry sand. I did it, and used play sand from the lumber yard (stored inside). It's been in there almost two years now.
10-03-2005 08:11:24
 Re: Lawn Roller filler in reply to Chuck MI, 10-03-2005 03:38:49
I like this idea better than my idea of washer fluid.
old
10-02-2005 19:52:55
Those where made to fill and then drain. Should not have water in it over any long term.
