M-F 3pt mower
Ohio/Farmer
10-02-2005 07:35:56
My sister in law has a very nice Massy Fergerson 3pt mower with 7ft bar, looks very nice, and has some extra kniefs with it, anybody got an idea what this may be worth, Thanks
kopeck
10-03-2005 17:03:46
 Re: M-F 3pt mower in reply to Ohio/Farmer, 10-02-2005 07:35:56
The older machines had a pattern of the even numbers being pitman arm (32, 42) and the odd numbers where wobble box (31, 41).
Hope that helps.
Edd in KY
10-03-2005 13:35:53
Check the model number plate on the gear box. I've bought 4 in the last couple years so I can give you a price range if it is the model I use.
Jim.UT
10-02-2005 16:12:09
Does it have a pitman stick or a wobble box? The wobble box design can be more versatile since you can mow at different angles. A pitman design can only mow horizontal.
Old sickle mowers seem to run a wide range of prices depending on location, etc. I've seen them sell for $50 and I've seen them go for $700.
Spare knives are no big deal. Most sickle knives are pretty generic and can be had at farm supply stores. Other parts might be a problem to find if needed.
