JD 224 baler knotter question
Pete Hatlestad
10-02-2005 06:55:11
I have a JD 224 baler that works really nice except when I get into tougher hay. There is one of the knotters that doesn"t let the knot off of the bill and breaks the twine.
This baler rally makes nice square bales. When the hay is nice and dry the baler works perfect. Do I need to loosen the spring on that knotter?
Thank you for you thoughts... Pete
Dave H (MI)
10-02-2005 07:06:44
 Re: JD 224 baler knotter question in reply to Pete Hatlestad, 10-02-2005 06:55:11
I have two of these 224T balers and have very little problem with them. The one problem I remember very well is when I first used one and the knotter on one side did not release the knot and as a result there were bales only tied on one side. If this sounds familiar, try the following:
There is a bolt that holds each knotter assembly down. Take the bolt off the knotter in question.
Flip the knotter up so you can see inside there. The problem in our case was incomplete movement of the swiper that pushes the knot off the bill hook (thing that holds the knot). You need to clean the mechanism really well and move the swipe back and forth thru it's full range. Compare it to the good knotter if not sure. Clean the bad knots off the bill hook and refasten down the mechanism. Grease it and run a few of your bad bales thru it by hand (CAREFULLY!) and see if it starts working. The baler works harder in heavier hay and that is when problems show up. If this is not your problem, try posting again with more specifics and I will try to find it in the manual. These are really good old balers.
Pete hatlestad
10-02-2005 12:25:44
 Re: JD 224 baler knotter question in reply to Dave H (MI), 10-02-2005 07:06:44
Thanks much for your help... Pete
Dave H (MI)
10-02-2005 19:43:48
 Re: JD 224 baler knotter question in reply to Pete hatlestad, 10-02-2005 12:25:44
Absolutely! Hope it works for you.
Dave
