john deere van brunt mdel b
gunner
10-02-2005 04:12:54
I just bought what I believe to be an van brunt model b. the id tag is hard to read but i think that is what it is. Is almost 13 feet wide wheel to wheel has galvanized seed boxes, all levers work fine and it has 18-7 on the gal box. I believe something is missing from the control to lower it to the ground, there are some brackets that look like there should be a rod that goes through it leading to the front of the tongue. Any info on the age, how to engage and lower the disks to the ground and if a operator and parts manuel are available wounld be appreciated. Also I believe that it has seen some recent use as all levers for seed flow work fine, discs are not rusted and it is very well greased.
Glen in TX
10-02-2005 11:12:39
 Re: john deere van brunt mdel b in reply to gunner, 10-02-2005 04:12:54
I'm not real clear on your description of lift either but sounds like you need a hydraulic cylinder or ratchet screw jack. The drills had those type lifts or levers or a chain lift ground drive clutch lift. There was a model B, B-B, & B-C and variations of those. Sounds you have 18 openers at 7" spacings. JD will have copies of the manuals for it 800-522-7448 or check their site. Local dealer if a good one might even have a manual holed away?
TomTX
10-02-2005 05:05:38
A picture would be a great assist, but without it I would guess that you have a drill set up for a remote hydrolic cylinder. And, yes Operator Manual and the Parts Manual is available thru JD.
