gear box bushhog
RandyNark
09-26-2005 20:55:19
wanted to know if any of you have ever taken a gearbox off of a three point bushhog and used it on a pull type bush hog. I have a pull type bush hog that the gearbox is worn out and my farmall does'nt have 3 point, would like to know if I could buy a used 3point brush hog and use the gear box to replace mine. please let me know . thanks in advance
Jerry/MT
09-27-2005 21:37:32
 Re: gear box bushhog in reply to RandyNark, 09-26-2005 20:55:19
For whatever my opinion is worth, I can't see any reason why a gearbox off a 3 pt bush hog is any different from the gear box on a pull type bush hog as long as it is rated for the same horsepower and it has the same overload protection (shear pin or slip clutch).
old
09-26-2005 21:36:16
I my area its cheaper to buy a pull type hog then a 3 point hog. So you may be better off just getting a good used pull type hog.
