Who Made The Best Equipment....
sammy the RED
09-24-2005 12:02:46
I'm talking about equipment made in '40's, 50's and 60's only, for general purpose farming.
My opinion on the following:
Tractor.....IHC Farmall... ;o]
Plow, Trailer Type.... IHC and Oliver
Corn Planter..... John Deere
Hay Baler..... New Holland
Disc Harrow....IHC
Corn Picker, Mounted..... IHC
Corn Picker, Pull Behind..... New Idea
Combine, Pull Behind.....Allis-Chalmers
Combine, Selp Propelled....Massy Harris
Grain Drill.... Oliver, IHC and John Deere
R Wyler
09-27-2005 14:50:10
 Re: Who Made The Best Equipment.... in reply to sammy the RED, 09-24-2005 12:02:46
CASE everything ;>) Especially tractors and plow's.
sammy the RED
09-27-2005 15:29:55
 Re: Who Made The Best Equipment.... in reply to R Wyler , 09-27-2005 14:50:10
You must not have baled hay with a Case baler !
R Wyler
09-27-2005 17:49:52
 Re: Who Made The Best Equipment.... in reply to sammy the RED, 09-27-2005 15:29:55
No I never have and never ran a baler. Sounds like you don't care much for a Case baler :>)
Dave H (MI)
09-25-2005 15:59:18
IH made a trailer plow????? First I heard of it!
Ya got any pics? :-)
sammy the RED
09-26-2005 16:16:59
 Re: Who Made The Best Equipment.... in reply to Dave H (MI), 09-25-2005 15:59:18
You lose the ones I e-maild ya ?
Hugh MacKay
09-25-2005 12:37:37
Sammy: The answer is so simple. Of the 8 to 10 mainline companies back then, it was the one that had the best dealer network in your area. Plain and simple that equipment was only as good as that guy right in your hometown that gave you sales, parts and service.
I've said many times, I've yet to see what I consider the perfect tractor. Same can apply to implements. I don't think I've ever seen a tractor or implement from those 8 to 10 companies that didn't have at least one feature I liked. IH 45 baler may be an exception, wasn't much to like about those.
tim[in]
09-25-2005 07:03:37
tractors allis /ford/massey/ minnie/ih plows oliver/allis disc kewannee/dunham cultipackers dunham planters jd/ih balers jd combines allis/ massey pickers new idea/allis /wood bros-dearborn drills oliver/ minnie
Chris Brown
09-25-2005 05:43:51
tractors must be red with an IH logo on it somewhere!
square balers: Deere.
round balers when they came out: New Holland chainers.
combines are made from galvanized steel: A-C of course.
trailer plow:All I have ever used were IH,so I cant be objective there. Disk harrow: IHC, But an Oliver ain't bad.
Grain drill: deere is all I ever used.
Mower/conditioner: IHC
plain sickle mower:New Idea.
And Pick-ups are always Ford's and usually painted red.
Don-Wi
09-24-2005 21:16:04
Well, that's a whole can full of worms there, but I'll throw in my opinion. Tractor- Ollie
Plow- Ollie
Chopper- Fox
Grain Drill-Deere (only one I know)
Corn Planter-Deere, again-only one I know first hand
Corn Picker-NI
sickle mower/haybine-NI
buickanddeere
09-24-2005 21:09:40
You must have had a round barn? The New Holland "banana baler" could not approach the square true bale that even an ancient Deere 14T or 214T could make. IH tractors the best? You must have been purchasing torque amplifier parts at wholesale prices. And getting your fuel for free from somebody else�s tank with a hose after dark.
James2
09-25-2005 12:30:06
 Re: Who Made The Best Equipment.... in reply to buickanddeere, 09-24-2005 21:09:40
Disregarding the 60's, which we all should know JD starting kicking some real butt, JD was continuously losing tractor market share. Rather than our collective biased opinions today, I probably believe the farmers at that time knew what was "best" and bought accordingly. This usually was IH, and it was not the cheapest tractor. No doubt late 50's JD diesels were great on fuel and I own a couple, but the gassers are nothing special, except the sound. We had NH balers and "banana bales" were never a problem and it had a lot more capacity than a JD baler. JD disks and drills were equal to any, but the plows had a tendency to pull "out" in heavy ground. Result was full width in lighter ground and something less when the pulling got tough. Definitely not as good as Oliver and IH. Pickers were always NI, and Woods Bros was a nightmare for belt wear/slipping. The Allis all-crop for it's size was likely the best all around pull type combine.
EARL-IL
09-26-2005 21:39:43
 Re: Who Made The Best Equipment.... in reply to James2, 09-25-2005 12:30:06
What model Deere plows wouldn't stay in the ground. All we had was mechanical lift they always worked Ok for us.Maybe it was because we couldn't pull them very fast. I have noticed when we plow now with our antique tractors the Oliver & IHC plows seem to pull easier and the moldboard are slanted back a little more than the old Deere plows. I have noticed the hydraulic Deere plows seem to come out of the ground if they don't have deep suck share. And also if they put a bigger tractor on and go too fast. We plow some seed corn ground and it gets pretty tough where those big trucks pack the fields down. Earl In Illinois
James2
09-27-2005 06:50:47
 Re: Who Made The Best Equipment.... in reply to EARL-IL, 09-26-2005 21:39:43
Earl:
Sorry I wasn't clear enough. The JD plows didn't come out of the ground they just didn't have enough strength, or weren't designed efficiently to use the steel/iron they had, to maintain a full width cut in hard ground. A older friend always said you could tell whcn someone was using a JD plow because the furrow/furrow wall was so crooked, looked like a snake path. Definitely would put models 66, 666, 55 and 555 in this class. Don't know about the 77 and 777 never saw any back home. Probably the 44 and 444 because they were so light.
Earl-IL
09-27-2005 07:27:20
 Re: Who Made The Best Equipment.... in reply to James2, 09-27-2005 06:50:47
I noticed that the plows will turn away from the furrow.When you get in real tough soil. I have seen several Deeres with wheel weights on the back end. It must have something to do with the draft. Weight wise that Oliver plow doesnt do that and they look to weigh about the same. Happy plowing. Earl In Illinois
buickanddeere
09-27-2005 20:00:32
 Re: Who Made The Best Equipment.... in reply to Earl-IL, 09-27-2005 07:27:20
Deere plows and tractor hitch have to be tweaked and tuned by somebody that knows what they are doing. Like any other peice of equipment It took me a couple of days to get my JD 415 somewhere close. Sway bar or chain adjustments critical. As are tractor rear tread width/offset from center to wheel furrow bottom. Some of my leveling problems disappeared with a few more psi in the tires. The tractor didn't squat as much when the pulling got harder. Even adjusting the rolling coulter depth and cut line made a significant difference.
James2
09-25-2005 12:51:26
Forgot to mention that I agree with the JD planter choice.
dave from MN
09-24-2005 12:28:43
Comparing to todays equipment lifespan and trouble free quality..... .. Any equipment made back then.
msb
09-24-2005 18:05:20
 Re: Who Made The Best Equipment.... in reply to dave from MN, 09-24-2005 12:28:43
You must have forgotten rotary hoes of the old days. Most were pure junk. The rest were only plain junk.
