Weight of an Oliver 2 bottom
old
09-21-2005 10:18:40
Plow? Its a 2 bottom 16 plow on rubber. I want to load it on my truck with my lift but it will only lift around 750lbs so is the plow to much for it?? Thanks
evielboweviel
09-21-2005 17:37:09
 Re: Weight of an Oliver 2 bottom in reply to old, 09-21-2005 10:18:40
4240 probably is pushing 550 lbs
Ron
old
09-21-2005 18:06:26
 Re: Weight of an Oliver 2 bottom in reply to evielboweviel, 09-21-2005 17:37:09
Thank U
RustyFarmall
09-21-2005 11:01:09
Give it a try, if the plow is too heavy the lift won't pick it up. I load and unload my IH 2-14s all the time using my H and loader, the tractor doesn't even know it is working. I really doubt if your plow weighs any where close to 750#.
old
09-21-2005 12:38:46
 Re: Weight of an Oliver 2 bottom in reply to RustyFarmall, 09-21-2005 11:01:09
Guess I should have said a little more about this lift. Its a swings boom lift that is mounted on the side of the bed. Has a 1000lbs boat trailor wench mounted on the top of it and a hyd, jack to lift the arm. Found out the hard way that it wouldn't lift a 6 foot brush hog and broke it at the base. I've fixed it since just don't want to do it again. I'm taking the plow with me to a show since at this show there isn't much in the way of old equipment there.
Randy-IA
09-21-2005 13:38:23
 Re: Weight of an Oliver 2 bottom in reply to old, 09-21-2005 12:38:46
Hi Old , Don't know the answer to that but with some of the plows I've seen looking for one it would probably come close to 500 lbs . It would almost have to or it would float on the surface wouldn't it ? Or do you set plows up to always dig down and rely on the gauge wheel or three point and draft control to keep it steady and true ? I've been reading up on draft control on my Oliver and from what I can tell the plow goes kind of like this ~~~~~ in the ground when the draft control works right as it encounters differing ground hardness ? Anyway , that doesn't need a response unless you have the time . I guess I'd try lifting it slowly and watch the boom very closely . If it start's to bend you got your answer :+ 0 . ...Randy
old
09-21-2005 14:04:57
 Re: Weight of an Oliver 2 bottom in reply to Randy-IA, 09-21-2005 13:38:23
Part of the way a plow works is to pull its self in to the ground. You have to have it set so it has the tips or points of the plow angled down a little but not to much. On the type of plows I loading theres a wheel on both sides and the way there set is how deep it will plow. On a 3 point system its where you set your lever as to have far it goes down.
old
09-21-2005 14:04:32
