Sickle mower problem with pics.
R Wyler
09-20-2005 13:46:24
third party image
Case no longer has this item I am told and I need to replace it and the 4 rivets that holds it on. I need to replace the plate on one of my mowers and replace the rivets on the other mower as I attemped to remove the good plate off the other mower to use as a replacement. I would preffer to have both machines operable if I can just get this problem fixed.... The rivets have to be flush with the plate. These are Case #10 mowers. Can anyone tell me the size of rivets those take?? Should I try and fabricate that new plate??
R Wyler
09-20-2005 13:47:32
 Another pic in reply to R Wyler, 09-20-2005 13:46:24
third party image
This shows where these plates go on the mowers.
Randy-IA
09-21-2005 12:23:35
 Re: Another pic in reply to R Wyler, 09-20-2005 13:47:32
Hi , I've never seen a Case but from the pictures it looks a lot like my Oliver 415 piece . I made mine because it was just a flat piece of steel . If it is cast Good luck . Try matching it with the Oliver piece part # Z-5166 [ Wear plate ( knife head front ) ] . If it's the cap itself the oliver part # is 506 366 E . If you try and make it and it has a slight bend in the front you can either grind a radius into it or bend it before you cut it off to the right length .
If a regular sickle section rivet is loose in the hole then it's probably a #6 rivet X 3/4" . Unfortunatly they are unobtainable anymore . Counter sink a hole of your choosing and use a tapered machine screw or tap the holes in the plate and screw it in from the bottom and grind the tops off . If the front knife head cap uses the same holes then you are going to have to use your imagination . A good welding shop can do about anything you want done . Good luck ....Randy
R Wyler
09-21-2005 17:37:11
 Re: Another pic in reply to Randy-IA, 09-21-2005 12:23:35
Thanks for the info and # with these parts not being available anylonger fabricateing them is the only option.
