John Deere Model 44 Plows
Jon O'Connor
09-20-2005 11:49:47
Does anybody have any information on replacing the wheel bearings on the model 44? (transport wheels)
Jon O'Connor
09-23-2005 04:40:55
 Re: John Deere Model 44 Plows in reply to Jon O'Connor, 09-20-2005 11:49:47
Thanks Bob and Glen
Does anyone know if you can get aftermarket shares for these plows? I called JD and they wanted $100 a piece, and said their were 2 left in syracuse and 2 out in michigan somewhere.
Bob Collins
09-20-2005 14:03:35
If you have a #44 plow there are no precision bearings in the wheels, they used a replaceable chilled sleeve which is fairly easy to replace, I don't know if new are available though. A parts catalog or owners manual would be an immense help, and are available from Deere publications at 800 522-7448. If you have a #444 plow (disc wheels) it has roller bearings same advice goes for that one.
Glen in TX
09-20-2005 22:20:56
 Re: John Deere Model 44 Plows in reply to Bob Collins, 09-20-2005 14:03:35
Bob is right that it uses just a sleeve bearing. Both sides used a X264A sleeve and JDparts site says invalid number. Same sleeve for steel wheels or rim with tires on the 44, 44A, 44H, & 44AH plows. The tail wheel used a different part number on sleeve. If the cast box or shaft isn't too wore the sleeve can probably be made out of some machine bushing material or tubing turned and bored to fit. If it has the clutch lift box on one side then it rides on a cast box sleeve and a hub.
Glen in TX
09-20-2005 22:15:50
