Plow shares...What kind of steel?
jd50_tye
09-20-2005 06:54:25
What kind of steel are plow shares made of? Hardened? Cast? Thank you.
Joe(TX)
09-22-2005 10:24:46
 Re: Plow shares...What kind of steel? in reply to jd50_tye, 09-20-2005 06:54:25
Most were made of carbon steel like SAE 1080. Carbon steel is any of the 10xx or 11xx series. Lower grades (1020 etc) cannot be heat treated.
Butch(OH)
09-20-2005 07:40:35
Several differant materials were used but most often used around here was hardened and tempered carbon steel. One of my old manuals lists 20 different shares for the same bottom, listed for materials are cast iron, hardened steel, chilled iron, chilled steel. The different materials were for different soils, some soils dont wear and are sticky so the share needs to polish, some have rocks and cant be brittle, some are abrasive and wear out quickly. If you are going to make a share most often you can get away with hardened and tempered carbon steel. Search for blacksmithing- plow points for lots of internet info.
