boom pole question
Melville Will
09-18-2005 07:06:24
I just picked up a used 3 pt. boom pole for my TO 30. It's made of steel tube and looks like the one shown on the Howse website. I need to get a top link to use with it but I'm not sure know how long it should be. Any advice would be most appreciated!
Jim.UT
09-18-2005 16:40:17
 Re: boom pole question in reply to Melville Will, 09-18-2005 07:06:24
I bought a used King Kutter boom pole at an auction for $30. With a standard toplink I was having a problem lifting my truckbed toolbox out of the truck....couldn't make it go high enough. So I bought a shorty top link and now I can pick the box waaay up high. But If I want to set it down I have to set it on a set of sawhorses.
Different circumstances may dictate different needs. Get a long toplink and a short one so you're covered no matter what you need to lift.
KX
09-18-2005 15:16:11
I just use a piece of chain with a hook on it and hook it as long as I need in the place of the top link.
supergrumpy
09-18-2005 10:43:11
I inherited an old timer that is worth its weight in gold, no idea of the brand
using standard upper link it won"t go far enuf down, bot extra-long link at Tractor Supply and that did the trick
might want to add front weights if carrying heavy stuff
Bus Driver
09-18-2005 10:33:43
I use a hydraulic cylinder for the top link which extends the vertical travel range of the boom pole. But it requires an auxiliary (remote)hydraulic outlet.
old
09-18-2005 08:57:12
I just use a normal run of the mill adjustable center link
