How much HP needed to pull corn planter
Marcus
09-17-2005 13:47:34
How much HP is needed to pull a 4 row no-till planter. Something like a AC 333. Thanks
ELI
09-17-2005 18:48:09
 Re: How much HP needed to pull corn planter in reply to Marcus, 09-17-2005 13:47:34
I pull a JD 7000 4 row notill setup with a 30 HP kubota. I can pull it as fast as I want (5 to 6 mph) even up hills. It has mfwd.
Tim(nj)
09-18-2005 15:14:56
 Re: How much HP needed to pull corn planter in reply to ELI, 09-17-2005 18:48:09
Just be careful turning at the bottom of a hill if the tractor is not very heavy and you have fertilizer and seed boxes loaded to the hilt. I have seen a couple jack-knives happen . . . . .
hj
09-19-2005 16:49:07
 You shouldn't plant corn on hills!!!! in reply to Tim(nj), 09-18-2005 15:14:56
keep your corn on level ground. If you go on hills because you have no choose use your harvesting tractor to plant it!!!
