Need Parts for NEW IDEA 30A Sickle Mower
George88888
09-15-2005 17:21:19
I am looking for the bearing assembly for this mower. This is the bearing that attaches to the pitman arm on one side to the gearbox wheel on the other side. This is the "cam" that drives the sickle. I need the pin that goes in the wheel bearing and bearing holder (These are not the exact names of these parts). Used are fine. Please send me an email, even if you post to the discussion group, or I will likely miss your message. Send message to handyman AT centralpets DOT com.
PS. I may need other parts too. Just bought the mower and this bearing assembly was missing. I am not sure what else might be broken when I run it. Let me know what you all have.
Thanks
George
Leroy
09-16-2005 16:43:27
 Re: Need Parts for NEW IDEA 30A Sickle Mower in reply to George88888, 09-15-2005 17:21:19
George, Where are you located, I may also have what you are needing. Leroy, West Central Ohio
Errin OH
09-16-2005 08:18:43
I have one that is heading to the scrap yard pretty soon. Was working ~ok when parked couple years ago. Between the lift not latching everytime and robbing parts (wheels & pto) It's not worth much any more. Where you located?
Don-Wi
09-15-2005 21:22:11
I've got a handfull of old parts for a NI sickel mower my grandpa used to have. Got somewhere around 20 guards, 2 new and the rest vary from good to fairly worn. Also have a handfull of ledger plates and possibly some new sickel blades, although those can be had anywhere. I've also got a pitman minus the bearing you are talking about. Only have the steel tear-drop shaped pc. the the bearing bolts to. I'd be willing to sell you the wholoe lot for say.... 50 bux?
Donovan from Wisconsin
Wisconsin Bill
10-28-2005 21:31:57
 Re: Need Parts for NEW IDEA 30A Sickle Mower in reply to Don-Wi, 09-15-2005 21:22:11
I could use rims and tires. And that little wrench to release sickle from wobble head. I am 1 hour N of MIlwaUKEE.
