PO Breaker Plow Lift Help
Redd
09-10-2005 18:23:31
I have a 20"? one bottom P&O Land Breaking plow on steel. It is a good plow but when you trip it to lift at the end of the round it starts to lift and gets about halfway a drops down. I'm not a trip-lift plow man. I looked inside the lift. The lobes? don't look worn too bad. Can someone help? I don't think the lift on this is any different from a regular plow except maybe bigger.
RustyFarmall
09-11-2005 14:28:21
 Re: PO Breaker Plow Lift Help in reply to Redd, 09-10-2005 18:23:31
You are holding onto the rope too long. One short tug on the rope is all that's required, otherwise the plow will do exactly what you have described.
Bret4207
09-11-2005 05:04:49
Pretty sure IH bought P+O so if their lift mechanisms are similar heres what I'd do. Pull the cover off, catch all the little pieces, clean everything up with diesel and PB Blaster, re-grease, re-assemble and try it. Also make sure the springs that control the lift mechanism are stout enough to work. Wish I had a brush and breaker plow. Be handy in the old meadows.
Redd
09-11-2005 09:00:35
 Re: PO Breaker Plow Lift Help in reply to Bret4207, 09-11-2005 05:04:49
I kind of did that, cleaned out a mouse nest and put on some spray moly. Then I was afraid that was the wromg thing to do. The lift roller starts to climb those ramps or lobes and then slips. I was wondering if that roller is worn down. I can't imagine this plow having that many acres on it. And we don't live in a sandy area.
pete7
09-11-2005 16:19:40
 Re: PO Breaker Plow Lift Help in reply to Redd, 09-11-2005 09:00:35
Hi Redd.
I have a different color plow and I don't know directly about the PO or IH plows, but on the lift for a JD (it also has lobes/roller), I had the same problem and the problem turned out to be a weak spring on the roller. The spring looked OK, but must have weaken over the years. I should have replaced the spring, but I was in a hurry and just shortened it a little and the lift has been working fine since.
Pete
